  • Internal process behind the restoring of data in computer
    sunildhimal
    sunildhimal
    @sunildhimal-ucUuwc
    Updated: Oct 20, 2024
    Views: 1.2K
    Hi😎
    I would like to know the internal process behind the restoring of data in computer..
    After deleting everything we can restore it back.how it is done internally??
    Thanks
  • Aashish Joshi
    MemberNov 24, 2009
    When you delete a file, even by Shift + del, the file does not physically get deleted from the hard disk. All that gets deleted is the path to the physical location of the file.
    In order to restore this file, a file recovery software is needed. These software look for files that exist on the hard disk but are not referred to by the OS (I think, not sure though).
    Even after you've formated your hard disk you can recover your files. However, this may not be possible if you've used low level formatting.
    Please correct me if I'm wrong.
  • sarveshgupta
    MemberNov 24, 2009
    Ya you are right whenever we delete a file the os removes the refering pointer or flag to the file and makes the space available to be used by another file
    But if we restore the deleted file before the space is filled up by some other data then, we can again make windows set the flag to 1 which means you have recovered your file
    That is why when you click restore the file again is available at the same location where it was previously.
    Please correct if I'm wrong.
  • vik001ind
    MemberNov 24, 2009
    This clarify all issues---
  • sunit.soni
    MemberNov 24, 2009
    mad_scientist
    Excuse me but backup don't make our deleted file back..
  • sunit.soni
    MemberNov 24, 2009
    sarveshgupta
    nice thing you told .Is it ture Really?
  • Manish Goyal
    MemberNov 25, 2009
    Hey can we set recovery points...???
    ie if i want then i can recover upto certain date??
  • sunildhimal
    MemberNov 25, 2009
    Thanks you all for the information.
  • vik001ind
    MemberNov 26, 2009
    goyal420
    Ya we can set recovery point by using backup & restore application & restore to certain dates. but it doesn't restore your data, its restores the software installed & other os setings. You can take backup to an external drive that will save your data.
  • Mahesh Dahale
    MemberNov 26, 2009
    TO create a System Restore point?
    Click Start, All Programs, Accessories, System Tools, System Restore
    For Classic Start Menu: Click Start, Programs, Accessories, System Tools, System Restore.
    Click Create a restore point, and then click Next.
    In the Restore point description box, type a name to identify this restore point. System Restore automatically adds to this name the date and time that this Restore Point is created.
    To finish creating this restore point, click Create.
    You can also launch System Restore window by typing the command below, in the RUN box:
    %SystemRoot%\System32\restore\rstrui.exe
  • Manish Goyal
    MemberNov 26, 2009
    Thanks mahesh for this information
  • Mahesh Dahale
    MemberNov 26, 2009
    goyal420
    check this link
