@harshad-ukH5ww • Oct 26, 2012
dossdssHello all,
i want to interface a bluetooth module with lpc 2148.
i am much familiar with c programing with lpc 2148.
but dont know anything about bluetooth n AT commands n all.
so please help me with all the steps for the above.
thank you.Can you tell us which bluetooth module you are using?
@dossdss-4lCGQo • Oct 26, 2012
godfatherCan you tell us which bluetooth module you are using?
yes sir, its the bluelink bluetooth module...
the very first step i am doing is reading the data sheet of that module...
but after that my problem is from where n how to start to implement it.
thank you for your concern. -
@harshad-ukH5ww • Oct 28, 2012
dossdssyes sir, its the bluelink bluetooth module...
thank you for your concern.Will you please share that datasheet here ?
@dossdss-4lCGQo • Oct 29, 2012
@harshad-ukH5ww • Oct 29, 2012
As per datasheet its seems Bluetooth is working with direct UART interfacing.
Have you gone through Commands listed in that sheet? Where exactly you are facing problems ? -
@dossdss-4lCGQo • Oct 30, 2012
helo sir,
actually the problem i was facing is solved for now, i we let you no the progress.
thank you. -
@harshad-ukH5ww • Oct 30, 2012
dossdsshelo sir,
thank you.It would be great if you share your application idea and progress or any video?
@ashiwni-zwD7wW • Mar 23, 2013
Can you share the code for the Blue Link interfacing with LPC 2138?
@aakashkaasina-Qk1ugh • Mar 27, 2013
What's an LPC 2138??
What is an LPC 2138???๐จ
@ashiwni-zwD7wW • Mar 27, 2013
@dossdss-4lCGQo • Mar 29, 2013
ashiwniCan you share the code for the Blue Link interfacing with LPC 2138?
yes i can send you the code for that..
but dont have it with me right now, so will do it asap.
till then tell me where you are stuck ? -
@arunchary-VtqB3c • Mar 30, 2013
hi,
tell me where your getting stuck such that i can provide you a solution...
