@thebigk • Dec 6, 2012
What do you think will happen? 😀satty lavanyawhat will happen when inductance is placed in dc and ac supply? -
@satty-lavanya-4IoUgk • Dec 6, 2012
i think that in dc supply it will act like a coil.but in ac supply ......i think inductor induces the magnetic field.... i dnt know crctly. plz help me -
@lal-R60Xjx • Dec 6, 2012
We know some basic facts. When electric current passes through a conductor, magnetic flux lines are formed around it. When the magnet flux linking with a conductor changes, an emf is induced across it.
In a DC supply, current doesn't vary with time as in the AC. So when a DC current flows through the coil, there would be magnetic flux lines formed around it. Since the DC is steady, these flux lines will also be steady. The coil will act as a solenoid now. If an iron core is placed inside the coil, it will act as a temporary magnet, electromagnet.
A 50 Hz AC current changes its direction 100 times a second. So the magnetic flux it creates also changes direction along with the current. When this alternating flux links with the coil itself, it induces an opposite emf which opposes the original applied emf due to self induction. It thus opposes the change in current. The inductor will make the current lag the voltage inan ac circuit.
Thus, an inductor doesn't affect the current flow in a dc circuit other than acting itself as a solenoid. But in an AC circuit, it will make the current lag behind the voltage. -
@pinank-6TUo5O • Dec 9, 2012
In DC supply we will have a transient response...where i(t)=Vdc/R(1-e^(-R/L)*t)...
While in AC supply the inductor will act as a solenoid where there will be back emf e=-Ldi/dt...
so integrating we get i(t)=Vmcos(wt)/Lw..assuming V=Vmsin(wt)... -
@satty-lavanya-4IoUgk • Dec 10, 2012
ca
can u explain the transient response.. in detail.........pinankIn DC supply we will have a transient response...where i(t)=Vdc/R(1-e^(-R/L)*t)...
@pinank-6TUo5O • Dec 10, 2012
well in transient response the current will rise exponentially and then attain the steady state value of i=V/R. but the transient responce will be given by i(t)=Vdc/R(1-e^(-R/L)*t)...
@jeffrey-xA7lUP • Dec 11, 2012
Some time is taken for an electric circuit to reach stable equilibrium. This time taken is called as transient time
The state of the circuit in this time is called as transient state. Here the response is not steady and it varies with time
