In Java Why Java class name and file name should be same?
micheal john
@micheal-john-l1fIn3 โ€ข Oct 26, 2024
i googgled and found some blogs saying
1) class name and file name should be same only when the class is public
but could not understand core reason for this approach?
๐Ÿ˜–
    @anoop-kumar-GDGRCn Jan 6, 2014
    A public class is meant to accessed by anyone and for the record a class file is byte-code format not in plain-text.
    Now how can you access a public class if NameOfTheFile and NameOfTheClass is not same?
    Edit: rephrasing , it will make you difficult organize your code.
  • micheal john
    @micheal-john-l1fIn3 Jan 6, 2014
    Anoop KumarA public class is meant to accessed by anyone and for the record a class file is byte-code format not in plain-text.
    yes i agreee,
    but my question is "class name and file name should be same only when the class is public?" is it true
    Yes,
    Otherwise you already know class name where to access. In that case no need to have same name.
  • Onkar Pathak
    @onkar-Dyydcl Jan 8, 2014
    In java, the class which contains public static void main that name and file name should be same.. because all other classes are accessed through main class and by giving file name same as class containing main you are refering to main.. hence it needs to be same....
    @anoop-kumar-GDGRCn Jan 8, 2014
    So the class with modifier public which do not have public static void main method
    can have different file name?
  • micheal john
    @micheal-john-l1fIn3 Jan 8, 2014
    Anoop KumarSo the class with modifier public which do not have public static void main method
    even i have the same doubt?
  • Anand Tamariya
    @anand-tamariya-DnfjEX Jan 8, 2014
    That's part of <a href="https://docs.oracle.com/javase/specs/jls/se7/html/jls-7.html#jls-7.6" target="_blank" rel="nofollow noopener noreferrer">Chapterย 7.ย Packages</a>:
    If and only if packages are stored in a file system (<a href="https://docs.oracle.com/javase/specs/jls/se7/html/jls-7.html#jls-7.2" target="_blank" rel="nofollow noopener noreferrer">Chapterย 7.ย Packages</a>), the host system may choose to enforce the restriction that it is a compile-time error if a type is not found in a file under a name composed of the type name plus an extension (such as .java or .jav) if either of the following is true:
    • The type is referred to by code in other compilation units of the package in which the type is declared.
    • The type is declared public (and therefore is potentially accessible from code in other packages).
    This restriction implies that there must be at most one such type per compilation unit. This restriction makes it easy for a Java compiler to find a named class within a package. In practice, many programmers choose to put each class or interface type in its own compilation unit, whether or not it is public or is referred to by code in other compilation units.
    There is no relation between public class/filename and public static void main. main method is just starting pointer of a java class (if class have this method with valid signature).
    Adding few more points to @#-Link-Snipped-# #-Link-Snipped-#
    -To ease javaDoc -
    The -javadoc command processes a source file only when the file fulfills all of the following requirements:
    The file name prefix (with .java removed) is a valid class name.
    -To avoid multiple public classes in one file
    This restriction makes it easy for a Java compiler to find a named class within a package. ๐Ÿ‘
  • micheal john
    Thanks guys now i understood why java public class name should be same as file name๐Ÿ˜€
  • infoj
    @infoj-io05KE Jul 5, 2015
    why even that restriction to have the same name as class name at run time.
    Answer is that is how java interpreter will know which class to load and where is the entry point (main() method) otherwise interpreter may have to scan a lot of class files to determine where to start.
  • Kunal Deshpande
    @kunal-jIgtGq Jul 9, 2015
    As long as you don't have a public class in your source file, you can name your source file to any name and can compile. But, if you have a public class in your source file, that file should have the name same as your class name. Otherwise, compiler will throw an error.
  • msajaa
    @msajaa-u9OG7Q Jul 9, 2015
    Answer is simple,because to make sure there is no confusion while compiling and running the program.
  • msajce
    @msajce-1SfF7s Jul 10, 2015
    We say this statement that the file name should be same as the class name to make sure there is no confusion while compiling and running the program.
  • Gnanam Ramalingam
    @gnanam-ramalingam-FIEX4Z Dec 24, 2015
    The compiler will generate a .class file with the name of the class at the time of executing we need to specify the name of the class to be executed i think this can be a one of the reason to name the source code file with its class name...............this is what content i have refered
  • Gnanam Ramalingam
    name of the file should be named after the class which holds the main function
  • rahul69
    @rahul69-97fAOs Jan 10, 2016
    Logical answer: Java was made that way, C++ wasn't ๐Ÿ˜‰.
