I want some help in my project
eng_SaLoM
@eng-salom-9bZGjo โ€ข Oct 10, 2024
First of all i am happy to be with you all, i am a fourth year electrical engineer , me and my friend are planing to work in a project , and its about controlling home electricty whether by computer using a router or my phone, i know it seem a simple project for some of you , but i need some clue about it , and if there is a more interesting project, tell me about it because this is my final project ๐Ÿ˜.
Thankyou
    @thebigk • Sep 1, 2011
    Eng: Not sure where you're stuck. The project looks interesting enough and it all depends on how you implement it and what feature set you decide.
  • eng_SaLoM
    @eng-salom-9bZGjo • Sep 2, 2011
    Thankyou admin for your fast reply ,, well i weill use a modem, a pic , and ofcourse i will need interface between them, ,, what i am asking is where i can find information that will help me in doing this project,, and if there is anything you can give me advice on , i will be thankful.
  • Rupam Das
    @rupam-das-wW5CvN • Sep 4, 2011
    eng_SaLoMThankyou admin for your fast reply ,, well i weill use a modem, a pic , and ofcourse i will need interface between them, ,, what i am asking is where i can find information that will help me in doing this project,, and if there is anything you can give me advice on , i will be thankful.
    1) First arrange a PC and Ensure that it has parallel Port. Not Laptop. Ok. PC. New PC will have slots. You can connect a parallel port in slot. If the Slot is not there, you can connect an External one for 7$.
    2) Install .Net 2010, if your operating system is Vista 32bit/64 bit or Win7. Else install .Net 2008 for Xp (Sp2 is mandatory)
    3) Now parallel port has 8 data pins, 5 control pins. So in a simple way you can control 13 devices efficiently.
    4) Hardware Setup.
    A relay 6v,Optocoupler, 230 v, and As electrical Engineer you must be knowing how to control the bulb through a relay. Nice Now just connect one pin output from the LPT data port to relay. It can be programatically controlled through a very very very simple program in .Net. you need to download inpout32.dll for xp, and inpout64.dll for vista/win7. You can search for "Parallel Port Programming" + C#.Net + inpout32.dll. You have the program.
    5) For controlling Fan, you can have a regulator with each step connected to a relay. Never try for a Heater and Refrigerator!!!!! You can even go for TV on off.
    6) Taking the Command
    Options: a) Through SMS, GSM
    b) through Bluetooth
    c) Through Internet
    d) Through Voice
    e) Laser Light
    f) TV remote
    g) Telephone
    Clarify, what method you are interested on. I will provide the guidelines. Trust me. It is a fab project. I Value the effort more than than anything for evaluating a project. Remember building a Radio by yourself is a better project than purchasing an INR 20,000/- project with RFID, ARM micro controller and so on. This is a work that you can certainly work into.
  • eng_SaLoM
    @eng-salom-9bZGjo • Sep 4, 2011
    Thanx a lot rupam i reallly appreciate it ,, i will start working on it ,,, because its best thing when you do something and u make mistakes and you try it again and again till you manage it and succeed ,, thanx again
  • Rupam Das
    eng_SaLoMThanx a lot rupam i reallly appreciate it ,, i will start working on it ,,, because its best thing when you do something and u make mistakes and you try it again and again till you manage it and succeed ,, thanx again
    Dear eng_SaLoM, What we achieve is very small , but what we do to achieve that is what is the most interesting part. So dont fear a failure, even a filure will teach you manything. And we are there to guide. Go ahead. I will Guide you in each step. No problem.
