I need help with memory desiging.
Hello guys,
I'm so confused with this course called Computer Organization, I have an important assignment that I cannot solve, even though it seems to be easy.
Please guys help if you can answer even one question, provide me with the solution please
Problem 1
-What is the difference between DRAM and SRAM in terms of application (how they are used)?
[FONT="]o[/FONT]SRAM:
§Used for cache memory.
§Uses internal flip flops to store information.
[FONT="]o[/FONT]DRAM:
§Used for main memory.
§Used to store binary information in the form of electric charges.
-What is the difference between SRAM and DRAM in terms of characteristics such as speed, size, and cost?
§Faster than DRAM but it takes more space.
§More expensive and faster than DRAM.
§Does not need refreshing.
§Much smaller but slower than SRAM.
§Cheaper than SRAM.
§Needs refreshing.
[FONT="]o[/FONT]Type Speed Density Cost
DRAM Slow High Low
SRAM Fast Low High
-What are the differences between EPROM and EEPROM and flash memory?
[FONT="]o[/FONT]
-How does SDRAM differ from DRAM?
[FONT="]o[/FONT]SDRAM is a new faster type of DRAM.
Problem 2
The figure below shows how to construct a 1 Mbytes memory module based on chips of 512 by 512 bits. The module is composed of 4 groups of 256 K-byte blocs.
![[IMG]](proxy.php?image=http%3A%2F%2Ffile%3A%2F%2F%2FUsers%2Frawan%2FLibrary%2FCaches%2FTemporaryItems%2Fmsoclip%2F0%2Fclip_image002.png&hash=c1d4fe8db8cf38009ba0dd31a0849929)
Let suppose that this module is a single chip of 1 M-byte where the word is 1 byte. So, the chip has 20 address lines or bits (consider that the whole address lines are used and not half of them as usual) and 8 data lines.
1-Give a high level chip diagram of how to construct an 8 M-byte memory using these chips. Make sure to show the address and the data lines and how they are used.
Give a high level chip diagram of how to construct an 8 M-Words memory, where the words are on 16 bits, with these chips. Make sure to show the address and the data lines and how they are used
I answered problem 1 but still not sure about the answer
while i couldn't answer problem 2😔
thank you very much.
