    @thebigk • Oct 27, 2013
    We need a better knowledge of your overall setup. How is your Laptop connected to the Internet? If it's connected through a dongle, then you will have to turn your Laptop into a wifi hotspot. You haven't told us which operating system is running on your machine, so the steps to convert laptop into a wifi hotspot will be different. I'd recommend searching on Google with following keywords: How to turn <Operating System> into Wi-Fi Hot Spot". Google should throw you all the perfect search results.
    If you still face problems, please provide us all the information about your setup and tell us at what step you are stuck. I'm sure you will receive all the help here.
  • Ahsanul haque
    @ahsanul-haque-2o7iUb • Oct 27, 2013
    I'm using windows7 professional 32bit.
    Ahsanul haqueI'm using windows7 professional 32bit.
    Did you search online for steps to convert your laptop into wifi hotspot? Has your problem been solved?
    @anoop-kumar-GDGRCn • Oct 27, 2013
    If your laptop connected to Lan then only you can share through wifi hotspot.
    If wifi being used as internet source for laptop then you can use bluetooth or USB pc suite to browse on mobile.
  • Ahsanul haque
    According your direction about googling i got a video its not working good, i cant used internet in my mobile.
  • Ahsanul haque
    @ahsanul-haque-2o7iUb • Oct 28, 2013
    Its not working ....in my laptop. dont follow this video..
