@anoop-kumar-GDGRCn • Feb 4, 2016
Aravind203I would like to restrict the access of fingerprint when the person is sleeping or unconscious. Is it possible to do?
Here are the options:
- This will need a programmed mind to change the finger pattern actually of finger when they get unconscious.
- Wear a transparent material when you thing your finger print should not accessed
@aravind203-MruuRh • Feb 4, 2016
Actya
Anoop KumarHere are the options:
Actually I was thinking about doing a project on this.can this be turned into a project?
You have to think all the aspects...
- You can't change the finger print on human body...
- You can disable the finger print locker on rule basis..when person is sleeping. This may be done using AI, you need to program.
Can you suggest any IOT related projects?
@koushal-C6mEgp • Feb 5, 2016
In stead of doing anything with fingerprints, why can not we concentrate on consciousness.
Fingerprint scanner would only work, when there is some consciousness, else it would not work. Going ahead, I would try to find out what factors can not be made active from external forces for a person who is sleeping or in any position like that and will let here hear.
