How to compile with GNU compiler on UNIX system.
sushant005
@sushant005-tyt4WK • Oct 22, 2024
I an using Ubuntu 10.04 as my OS and i installed GNU C++ compiler wants to know that what is the command to compile C++ program on UNIX system?
Is there any necessary software required to run C++ program?
Help me out !!
  • Aashish Joshi
    @aashish-VrevFC • Aug 11, 2010
    you might wanna go through the following links:
    <a href="https://ubuntuforums.org/archive/index.php/t-401823.html" target="_blank" rel="nofollow noopener noreferrer">ubuntuforums.org</a>
    You'll need to install gcc/g++. Open the synaptic package manager and search for the appropriate package and install it. You will of course need internet connection.
    [EDIT]
    On the other hand, open the terminal window and run the following command. This should be all you need:
    sudo apt-get install build-essential
