Help! - Java Problem
Hey Guys!
I started on Java Programming yesterday(on my own), and im having a bit of trouble..
Here is the code i wrote(bear with me please, i only started yesterday):
import java.util.*;
public class calculator {
public static void main(String[] args) {
Scanner ip = new Scanner(System.in);
double fnum , snum, ans;
char resp;
System.out.println("Enter the first number:");
fnum = ip.nextDouble();
System.out.println("Enter the second number");
snum = ip.nextDouble();
System.out.println("Enter the operation: [+,-,*,/]");
resp = ip.nextLine().charAt(0);
if(resp == '+'){
ans = fnum + snum;
System.out.println("Answer is "+ ans + ".");
Right, this program is a simple calculator. I have completed only a part of it(addition only ๐ ).
If i run this program it shows up this error :
Exception in thread "main" java.lang.StringIndexOutOfBoundsException: String index out of range: 0
at java.lang.String.charAt(Unknown Source)
at calculator.main(calculator.java:14)
so what have i done wrong?
the command i used is
is for taking the first character enterd isnt it?(im using this bcoz there is no '.nextChar();')
I use the Eclipse IDE for Win-32
-Thanks ๐
