Gasoline Direct Injection
mechky
@mechky-jbqpJD โ€ข Oct 23, 2024
Is there any car in India which is coming with a petrol engine using GDI (Gasoline Direct Injection) technology?
What I know is that every petrol engine nowadays uses fuel injectors which are basically port injectors, that are located on the intake ports rather than the combustion chamber. Only diesel injectors are located on the combustion chamber.
Also, if a petrol injector is used for direct injection i.e mounted on the combustion chamber, then will it be able to sustain high temperature of the combustion chamber?
