Doubt in java programming.
Morningdot Hablu
@morningdot-6Xuj4M โ€ข Oct 7, 2024
Hello friend's,
Check out this program.
import java.io.*;
public class r
public static void main(String args[])throws IOException
try
FileReader fr=new FileReader("mohit.txt");
FileWriter fw=new FileWriter("monu.txt");
int s;
while((s=fr.read())!=-1)
fw.write(s);
catch(Exception e)
System.out.println("exception occured ");
What's wrong with this one..??
  • Saandeep Sreerambatla
    @saandeep-sreerambatla-hWHU1M • Sep 29, 2010
    You have to use fw.close(); after the while loop.
  • Morningdot Hablu
    @morningdot-6Xuj4M • Sep 29, 2010
    Yeh it's working.
    Now i comes to the main problem what i faced.
    Check out this program ES
    import java.io.*;
    public class r
    try
    FileInputStream fr=new FileInputStream("mohit.txt");
    FileOutputStream fw=new FileOutputStream("monu.txt");
    int s,d;
    s=fr.read();
    fw.write(s);
    catch(Exception e)
    This program will be written using byte stream in this program i didn't close the streams and it's working but in the case of character stream we must have to close the stream's.
    Can you tell me the reason why..??
    This is the information I found from a friend!
    In the FileReader operation the data is written onto Buffer it seems, and you can use flush() or close() for getting the file written!
  • Morningdot Hablu
    Thanks ES !!
    I got the answer.
    @saandeep-sreerambatla-hWHU1M • Sep 30, 2010
    @Mohit:
    Read this point , we need to close the file stream as well.
    Always Close Streams ,Closing a stream when it's no longer needed is very important โ€” so important that CopyBytes uses a finally block to guarantee that both streams will be closed even if an error occurs. This practice helps avoid serious resource leaks.
