    @anoop-kumar-GDGRCn • Aug 1, 2016
    Another way, design like this.
    oneway
    You can only screw it but when you try to unscrew, screw driver will not able to hold it.
    <a href="https://www.naturalhandyman.com/iip/inffastener/infoneway.html" target="_blank" rel="nofollow noopener noreferrer">Security or One-Way Screw Removal Methods</a>
  • Swathy Prabhakaran
    @swathy-460Vwm • Aug 1, 2016
    Anoop KumarAnother way, design like this.
    oneway
    thanks anoop ji
  • Vipin verma
    @vipin-HbdgKw • Aug 2, 2016
    For normal purpose minus screw and for medium purpose plus screw and for higher purpose depth plus screw is better,
    For tightening triangular, square, Pentagon upper base type, to reduce looseness
  • Vipin verma
    Like this types
  • Stephen B Johnson
    @stephen-b-johnson-lrt5rX • Aug 16, 2016
    You should make it left handed too. Then you could sell left handed screwdrivers.
    I already have left handed wrenches and a left handed hammer.
    @swathy-460Vwm • Aug 16, 2016
    Stephen B JohnsonYou should make it left handed too. Then you could sell left handed screwdrivers.
    thanks
  • T.Vikram Singh
    @tvikram-T5QIJK • Oct 16, 2016
    oneway
    when it can be tightened it can also be loosened,
    i'm unable to understand how it can only be used for tightening but not loosening..//
    How ?
    @anoop-kumar-GDGRCn • Oct 16, 2016
    vikram singh t,
    How ?
    Tightening : Rotate right/clockwise - You see upper right edge will hold the screw.
    but, in Loosening : Lower right edge is not there it will not able hold screw and it will just slip.
    Try with common screw and see the effect.
