  • Varsha0802
    @varsha0802-YohNRX Mar 26, 2011
    Yes, steel is more elastic than glass.
  • CIVILPRINCESS
    @civilprincess-308hDv Mar 26, 2011
    definitely steel
  • ShrinkDWorld
    @shrinkdworld-WWdBBc Mar 26, 2011
    ya steel is more elastic !
  • ISHAN TOPRE
    @ishan-nohePN Mar 26, 2011
    If you go by the definition of elasticity, then you will come to know that the material which opposes deformation is more elastic.
    You may try by pulling both glass and steel from two ends. You will know it instantly that glass breaks while the steel rod does not.
    (Though you cannot perform this experiment manually. You will have to take the help of a machine because the force required is very huge.)
    The modulus of elasticity of steel is 2*10^9 N/mm2 which is greater than glass (69*10^9 N/m2)
    Hence, Steel is more elastic than glass. 😀
