cube problem
Banashree Patra
@banashree-patra-m0OJwR • Oct 25, 2024
Imagine a cubic array made up of an n*n*n arrangement of unit cubes: the cubic array is n cubes wide, n cubes high and n cubes deep. A special case is a 3*3*3 Rubik’s cube, which you may be familiar with. How many unit cubes are there on the surface of the n * n * n cubic array?
  • ~on*kiyu
    @onkiyu-I1FNB7 • Apr 22, 2012
    zero
  • Banashree Patra
    @banashree-patra-m0OJwR • Apr 23, 2012
    ~on*kiyuzero
    please explain
    @ramani-VR4O43 • Apr 23, 2012
    Banashree PatraImagine a cubic array made up of an n*n*n arrangement of unit cubes: the cubic array is n cubes wide, n cubes high and n cubes deep. A special case is a 3*3*3 Rubik’s cube, which you may be familiar with. How many unit cubes are there on the surface of the n * n * n cubic array?
    6*n^2 - 12*n + 8 for n > 1
  • silverscorpion
    @silverscorpion-iJKtdQ • Apr 23, 2012
    6n[sup]2[/sup] - 12n + 8
    I think it can also be expressed as, n[sup]3[/sup] - (n-2)[sup]3[/sup]
    silverscorpion6n[sup]2[/sup] - 12n + 8
    The second is more elegant. It represents the actual situation. What we are considering is the outer cube minus the (n-2) cube within it. n^3 is the total number of unit cubes, (n-2)^3 is the number of unit cubes in the contained cube. Aesthetically the second solution is more satisfying.
