Creating CON folder in windows !!!
Dipanshu
@dipanshu-s9jmBn โ€ข Oct 26, 2024
HI MYSELF DIPANSHU SRIVASTAV
I READ ON GOOGLE THAT MICROSOFT CORP. IS UNABLE TO CREAT FOLDERS NAMED CON , LPT1, PRN, COM1...FOLDER WITHOUT NAME...BUT I CAN DO IT... I ALSO READ THAT IT IS IMPOSSIBLE TO MAKE FOLDER CON.....................BUT I WILL DO IT IT IS POSSIBLE.......We can create a folder with CON name. Create a folder and right click and select Rename option. Then just press Alt and without releasing Alt button press 255 from the keyboard and then type con. Thatโ€™s it. You will see a folder named CON.
Reason why you cannot rename it normally is it that CON is one among many system reserved names.
DIPANSHU SRIVASTAV
BCA-MCA(DUAL)
LPU PUNJAB INDIA
<removed by admin>
  • itchap
    @itchap-RKJQDB • Aug 25, 2009
    Re: CON folder is possible
    DipanshuHI MYSELF DIPANSHU SRIVASTAV
    I READ ON GOOGLE THAT MICROSOFT CORP. IS UNABLE TO CREAT FOLDERS NAMED CON , LPT1, PRN, COM1...FOLDER WITHOUT NAME...BUT I CAN DO IT... I ALSO READ THAT IT IS IMPOSSIBLE TO MAKE FOLDER CON.....................BUT I WILL DO IT IT IS POSSIBLE........
    DIPANSHU SRIVASTAV
    BCA-MCA(DUAL)
    LPU PUNJAB INDIA
    Hi, Dipanshu First of all welcome to CE. And please post how to create a folder named con.
  • Dipanshu
    @dipanshu-s9jmBn • Aug 27, 2009
    ๐Ÿ˜contact me on <don't put your mobile number, unless you are a lonely individual who wants to talk to humans> then i will give the idea with sime terms & conditions
  • Saandeep Sreerambatla
    @saandeep-sreerambatla-hWHU1M • Aug 27, 2009
    There are ways described in internet regarding this !!!
    And BTW who wants to create that ??
    What are the uses of creating that file in system??
    Can you state what differences can we make creating a folder named CON?
    I guess its of no use creating that folder in windows.
    Any use please share!!
  • Dipanshu
    @dipanshu-s9jmBn • Aug 28, 2009
    Creating con foder in windows !!!
    DIPANSHU SRIVASTAV
    BCA-MCA (DUAL)
    LOVELY PROFESSIONAL UNIVERSITY UNIVERSITY,
    PHAGWARA,JALANDHAR-DELHI G.T. ROAD,
    PUNJAB
    <It has been said many times not to publish mobile numbers and email ids on open forums__ES>
  • Dipanshu
    Re: Creating con foder in windows !!!
  • Dipanshu
    itchapHi, Dipanshu First of all welcome to CE. And please post how to create a folder named con.
    DIPANSHU SRIVASTAV
    Clipped_ES>
    LPU PUNJAB
    BCA-MCA
  • oldboy1985
    @oldboy1985-MqDQ0e • Aug 30, 2009
    NOT WORKING !!
    AT LEAST IN MY PC
    please tell the reason
  • moksh
    @moksh-Nnq2IU • Aug 31, 2009
    thats a clumsy bypass....alt+255 is ASCII for "Blank space" so what ur actually doin is makein a con with space.... ๐Ÿ˜›
  • justaglance
    @justaglance-3T6eU6 • Sep 2, 2009
    Hi,
    It is not working for me ๐Ÿ˜”
  • enigma
    @enigma-7BlA8c • Sep 3, 2009
    good dude.....
  • Dipanshu
    @dipanshu-s9jmBn • Sep 3, 2009
    enigmagood dude.....
    thanks for regard
  • TARANJEET SINGH
    @taranjeet-singh-mdq4QW • Sep 4, 2009
    The BEST-EST BEST WAY OF CREATING FOLDER NAMED CON
    RUN>CMD> type the command with the drive letter you want: mkdir \\.\e:\con
    and to remove: rmdir \\.\e:\con
    but as u know that nothing is perfect in this world...so it has its own limitation.....just explore and find out....
    PLEASE COMMENT and also add me to your friend list...pleaseeeeeeeeeeeee
  • neha1
    @neha1-XOkqHl • Sep 4, 2009
    hi........
    i m able to make folder by name CONcon and not by CON.......๐Ÿ˜•y???
  • TARANJEET SINGH
    sorry neha1 I'm not getting you. please explain in detail. Do you want to say that u can't make con folder in uppercase????
  • namivrm
    @namivrm-w4iQGm • Sep 5, 2009
    sorry.......... but it's not working in my system... can u please give me cause why it is not working...
  • safwan
    @safwan-NH7W5Y • Sep 5, 2009
    well, I welcome all newbies and other CEans for their enthusiasm but, I have same questions as English_scared ๐Ÿ˜ก Why are we needed the folder name CON. my second advice to people please
    DO FOLLOW THE RULES OF CE
    PLEASE DONOT POST YOUR PERSONAL CELLPHONE NOUMBER AND EMAIL id. ITS NOT ALLOWED ON CE .
    BUT YOU CAN use PM (personal message ) option if you require.๐Ÿ˜€
  • sarveshgupta
    @sarveshgupta-txtmu5 • Sep 8, 2009
    hey and just look how many times you have posted the same post of how to create a con folder dipanshu
    it is not allowed
  • neha1
    @neha1-XOkqHl • Sep 11, 2009
    hey taranjeet i m not able to name it con only..but CONcon is going well
  • dipen30
    @dipen30-hGOPpa • Sep 11, 2009
    try this
    c:\>md\\.\c:\con
    delete that folder
    c:\>rd\\.\c:\con
    and enjoy
  • kanika_garg
    @kanika-garg-4cT8Du • Oct 21, 2010
    hey m nt getting,if its a predefined keyword then hw it can b created after using that alt+255..can u plz tel me?
  • Varsha0802
    @varsha0802-YohNRX • Oct 22, 2010
    try using d combination (alt+0160 ) - without brackets. it really works............
  • Kishan Gupta
    @kishan-gupta-IFXTPJ • Oct 22, 2010
    Hi guys, I search on google and found these points at one of the site.
    Not only CON, we cannot create any of these
    CON, PRN, AUX, CLOCK$, NUL, COM1, COM2, COM3, COM4, COM5, COM6, COM7, COM8, COM9, LPT1, LPT2, LPT3, LPT4, LPT5, LPT6, LPT7, LPT8, LPT9 and more
    The reason is that con, prn, lpt1..lpt9, etc are underlying devices from the time dos was written. so if u r allowed to create such folders, there will be an ambiguity in where to write data when the data is supposed to go to the specified devices. In other words, if i want to print something, internally what windows does is -- it will write the data to the folder prn (virtually u can call it a folder, i mean prn, con, etc are virtual folders in device level). So if we are able to create con folder, windows will get confused where to write the data, to virtual con folder or real one.
    Now to make con folder-
    Open the Command prompt by Start -> Run and typing cmd
    Code:
    C:\> md \\.\c:\con
    Now, Open My Computer and browse through the path where you created CON folder... Surprising.. ?? Yeah.. you have created it successfully
    Now, try to delete the folder from My computer
    OOPS!!! You cant delete it...
    Now, try this in command prompt console
    Code:
    C:\> rd \\.\c:\con
    Explanation of this:
    Well, let us now have a glance at how we were able to create it...
    It is just because of the UNC Path (#-Link-Snipped-#. The Universal Naming Convention, or UNC, specifies a common syntax to describe the location of a network resource, such as a shared file, directory, or printer.Since, these conventions did n't exist under pure DOS, they are not backward compatible. The UNC syntax for Windows systems is as follows..
    \\RemoteHost\sharedfolder\resource
    where RemoteHost is the computer name / IP address of the computer that you wish to connect through remotely for accessing shared folder. The rest is the path.
    (Here \\remotehost\drive:\con doesn't make sense anyway, because without having a process on the remote host, there is no current 'console'). It would be a security hazard as well, having the serial and parallel ports accessible for everyone who is allowed to read or write in any single directory.
    The "." in the command \\.\c:\con suggest the local server. Now, you are pointing to your own computer. since, you have all privilages on every folder of ur computer, you can easily create it.
    NOW I hope it is clear to everyone that what is real mystery behind this.๐Ÿ˜Ž
  • kanika_garg
    @kanika-garg-4cT8Du • Oct 22, 2010
    hey jcksn thanx
    but we can also create these folders with alt+255.then what was that...how it wil make the change..??
  • kanika_garg
    and also this command is not running at my machine...
  • whiz.kid.aniket
    @whizkidaniket-5IiBCq • Oct 22, 2010
    kanika_garghey m nt getting,if its a predefined keyword then hw it can b created after using that alt+255..can u plz tel me?
    if you press alt+255 (or alt + 160 for some comp.systems) you get a blank character, after that you type 'CON' which consists of 3 characters.
    ' CON'
    So there are total four characters (i.e 1.) Blank Character 2.) Letter 'C' 3.) Letter 'O' 2.) Letter 'N')
    Now these four characters you have created does not match with the original three!
    ' CON' is not equal to 'CON' (notice the blank character in first keyword)
    So this is how you can create CON folder.
  • Kishan Gupta
    @kishan-gupta-IFXTPJ • Oct 23, 2010
    Thanks aniket.
  • yogi_333
    @yogi-333-cMtiCe • Jul 14, 2011
    we can not create folder named con..............
    you create folder named con but it is not con it is <space>con.
    @thebigk • Jul 14, 2011
    I sometimes wonder why there's so much of interest in creating a folder named 'CON' on desktop ๐Ÿ˜
  • PraveenKumar Purushothaman
    @praveenkumar-66Ze92 • Jul 16, 2011
    @Biggie: When you say people to do this, they might not do... But something if you say don't do and cannot do, they will try to achieve it, or at least, try towards it... ๐Ÿ˜ Simple human nature, includes me... ๐Ÿ˜
  • sachin bankar
    @sachin-bankar-tI6gke • Jul 22, 2011
    Hi Dipanshu!
    Its niether working for me.
    @praveenkumar-66Ze92 • Jul 23, 2011
    I guess this thread is worth for nothing...
