    @thebigk • Mar 8, 2015
    Pooja ShreeVatsaI have few Data in Jpg I want to convert into excel....I wrote code but its not working ๐Ÿ˜”....someone Help me pls....
    Curious to know if you are actually trying to convert data available in an image (.jpg) to an excel file? If yes, please share the code you've written so far so that the experts here can help you fix it.
    PS: Please create a new discussion for every new topic that you wish to discuss.
  • Koushal Patel
    @koushal-C6mEgp • Mar 8, 2015
    Interesting!
    I have not tried though, found below links
    1. #-Link-Snipped-#
    2. #-Link-Snipped-#
    I will try to do this stuff once I get time, meanwhile, if anyone can pitch in with their idea, we would love to hear.
  • Pooja ShreeVatsa
    @pooja-shreevatsa-9yFvbt • Mar 8, 2015
    Kaustubh KatdareCurious to know if you are actually trying to convert data available in an image (.jpg) to an excel file? If yes, please share the code you've written so far so that the experts here can help you fix it.
    This s ma code .....
    import java.io.FileOutputStream;
    import com.itextpdf.text.Document;
    import com.itextpdf.text.pdf.PdfWriter;
    import com.itextpdf.text.Image;
    public class ImageToPDF {
      public static void main(String ... args) {
        Document document = new Document();
        String input = "c:/temp/capture.png"; // .gif & .jpg
        String output = "c:/temp/capture.pdf"; // png to pdf(output file)
        try {
          FileOutputStream fos = new FileOutputStream(output);
          PdfWriter writer = PdfWriter.getInstance(document, fos);
          writer.open();
          document.open();
          document.add(Image.getInstance(input));
          document.close();
          writer.close();
        catch (Exception e) {
          e.printStackTrace();
  • Pooja ShreeVatsa
    Can i Try it in Base64 String?...will i get proper output...
  • Manish Goyal
    @manish-r2Hoep • Mar 9, 2015
    I will suggest you following to debug this problem
    1st create a simple program to create a basic PDF through Java
    Below is working code
    <a href="https://www.avajava.com/tutorials/lessons/how-do-i-write-to-a-pdf-file-using-itext.html" target="_blank" rel="nofollow noopener noreferrer">How do I write to a PDF file using iText? - Web Tutorials - avajava.com</a>
    2: Write a Program to read data from Image, I think a simple read operation should work.
    3: Then merge both program and try to understand what is going wrong at every single point
    Just check if input is coming correctly or not
  • Pooja ShreeVatsa
    @pooja-shreevatsa-9yFvbt • Mar 9, 2015
    Manish GoyalI will suggest you following to debug this problem
    Thank you soo Much for your help....I ll try this..
