Configuring adc of tms470r1b1m controller
resmyanand
@resmyanand-HFRA4d โ€ข Oct 11, 2024
im using #-Link-Snipped-# controller for my project.i need an ADC for processing the analog input.
in iar workbench,i had configured the registers but the code is not working.
code is given below.plz give me a solution..........
#include <intrinsics.h>
#include "iotms470r1b1m.h"
#include "tms470r1b1m_bit_definitions.h"
#include <stdio.h>
void main(void)
  int result;
  PCR = CLKDIV_3;                         // ICLK = SYSCLK / 3
  GCR = ZPLL_CLK_DIV_PRE_1;               // SYSCLK = 8 x fOSC
  PCR = PENABLE;                         // Enable peripherals
  PLR = (PLOC3&0);                      //peripheral selects, The peripheral is internal
  PPROT = (PPROT3&0);             // peripheral selects,The peripheral is accessible in all modes
  CLKCNTL = 0x00000020;
  ADCR1 = PS_8;                          // ADCLK prescaler = 8
  ADCR1 = COS;
  ADCR2 |= G1_MODE;                       // Continuous Conversion
  ADSR =0x0000;                    // Clears flag
  ADEISR=0x0000;    // event disabled
  ADISR1 = 0x0020;   // Convert group 1 = channel 5
  ADISR2 = 0x0000;  //grp2 disabled
  ADCALR = 0x000;    //no Calibration
  ADSAMPEV = SEN;                        // ADCSAMP1 controls SW
  ADSAMP1 = 62;                           // SW = 62+2
  ADCR1 = ADC_EN;                        // Enable ADC
  for (;;)
   while (!GP1_END);             // Wait for conversion to complete
    result = ADDR5;
    printf("RESULT is %d",result);
    ADSR =0x0000;
when this code is executed in iar workbench, the ADC is not activated nor does it sets GP1_END bit to indicate the completion signal.hence the code never exits from the while loop.here input is given to channel 5.i couldn't identify the problem..
plz give me a solution.............
    @harshad-ukH5ww • Oct 12, 2010
    Have you tried a sample code given on the TI site?
    i had used ADC but it was on MSP series controller.
  • resmyanand
    @resmyanand-HFRA4d • Oct 17, 2010
    yes i tried the code...but its not working because the device is not selected
  • shreyasm89
    @shreyasm89-jGobVm • Oct 17, 2010
    Your 2nd error is because ADC isn't activated(obviously!)Also are you sure that the 'for' loop condition shouldn't have a bracket ending?Have you eliminated all syntactical errors?Also you have rewritten the value in ADCR1 twice in successive instructions. How come?
  • resmyanand
    @resmyanand-HFRA4d • Oct 18, 2010
    shreyasm89Your 2nd error is because ADC isn't activated(obviously!)Also are you sure that the 'for' loop condition shouldn't have a bracket ending?Have you eliminated all syntactical errors?Also you have rewritten the value in ADCR1 twice in successive instructions. How come?
    it is for(;๐Ÿ˜‰ unconditional for loop.there was no syntax error.
    i need ADCR1 to set -
    -COS(BIT15),CONTINUE ON SUSPEND ENABLE to continue channel conversion till completion when suspend mode is entered,
    -ADCEN(BIT5)to enable the ADC and
    -3 prescalar bits(bits 2,1,0).
    For this i had set ADCR1=8027 instead of the successive instructions.
    but the problem persists.....
