C Programming: How to Call Another Program from Main Program?
bharathkumarp
@bharathkumarp-kwU5lr โ€ข Oct 27, 2024
Hi CEans, in C language, is there any possibility to call another program from main program?
To call another program from a C program, you can use the system() function which is available in the stdlib.h library. The system() function executes a system shell command. It creates a shell command process, executes the command, and then returns once the command has been completed.
Here is a simple example demonstrating how to use the system() function to call another program:
#include <stdlib.h> /* Including standard library header files */
int main() {
    int return_value;
    /* The system() function takes a string argument that is the command to be executed.
    In this case, the command is the path to the other program that you want to run. */
    return_value = system("/path/to/other/program");
    /* The system() function returns an integer. This value can be used to determine if the system call was successful.
    Usually, if the value is -1, it means that the system call failed. */
    if(return_value == -1) {
        /* Handle the error accordingly. Here, we just simply print out a message. */
        printf("System call failed");
    return 0;
In the above example, replace /path/to/other/program with the path to the executable that you wish to run.
Please be aware that this is a simple example. The system() function has limitations and potential security risks because it invokes a shell command.
The shell can interpret special characters or environment variables, potentially leading to unexpected behavior if you pass in untrusted user input.
For more controlled execution of another program, look into fork() and exec() functions. These functions give you more control over input, output, and error streams, and avoid invoking a shell. However, they're also more complex to use.
Also, error handling for system() calls should be more robust in a production environment.
Error messages should be descriptive and possibly logged for troubleshooting. The error handling in this example is kept simple for demonstration purposes.
  • saurabh2486
    @saurabh2486-Tr6NOC May 9, 2010
    Re: C program doubt..
    i think yes its possible
  • sherya mathur
    @sherya-mathur-cI63wY May 9, 2010
    I will also go with saurabh
    yes it is possible in c language to call another program from main program
  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD May 10, 2010
    saurabh2486i think yes its possible
    sherya mathurI will also go with saurabh
    Can we know how this is done?
  • ms_cs
    @ms-cs-Ab8svl May 10, 2010
    Just make that file as header file and include it in the new file in which you want to use that file..thats it
  • bharathkumarp
    @bharathkumarp-kwU5lr May 10, 2010
    will you please provide me simple program code....
  • gaurav.bhorkar
    Ah! now I remember,
    If you want to run a program within a terminal using a C program, you can use the standard library function system ().
    Suppose we want to run the program "hello.exe", here's how we can do this,
    int main ()
        printf ("Before calling a program \n");
        system ("hello.exe");
        printf ("After calling the program \n");
        getch ();
        return 0;
  • bharathkumarp
    @bharathkumarp-kwU5lr May 13, 2010
    hi Gaurav, i executed the code which are provided by you.. It's executing only the printf statements but it not executing the block which are inside system.... Is there any header i need to include????
  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD May 13, 2010
    bharathkumarphi Gaurav, i executed the code which are provided by you.. It's executing only the printf statements but it not executing the block which are inside system.... Is there any header i need to include????
    Yes, you have to include stdlib.h for system() to work.
  • bharathkumarp
    HI Gaurav, this is also not working.. Only the printf statements are working...Without stdlib.h also it's showing the same output....
  • mayank1055
    @mayank1055-YWBPwq May 13, 2010
    yup it's not working
  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD May 15, 2010
    It works perfectly in Visual C++ Express Edition 2008.
  • bharathkumarp
    @bharathkumarp-kwU5lr May 15, 2010
    ok, i'll check it out... Thanks for the code...
  • silverscorpion
    @silverscorpion-iJKtdQ May 16, 2010
    Did you create the hello.exe file? Do you have it in the same directory?
  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD May 16, 2010
    silverscorpionDid you create the hello.exe file? Do you have it in the same directory?
    Yes the hello.exe file and our calling program's file should be in the same directory.
    The hello.exe must be created, it can have anything like printf ("Hello World \n").
  • bharathkumarp
    @bharathkumarp-kwU5lr May 16, 2010
    ya i put the file inside the same directory,but it is not working.....
  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD May 17, 2010
    bharathkumarpya i put the file inside the same directory,but it is not working.....
    Which compiler are you using?
    If you are using VC++, then your program's executable is in the debug directory. That is, My Documents/Visual Studio/Projects/<projectname>/Debug.
    Now paste the hello.exe into this directory.
