@reachrkata-FOcqhH • Jul 12, 2009
Using For Loops and Character comparison.
-Karthik
๐ -
@samaira-P4RsEf • Jul 13, 2009
that's quite obvious but i m not able to get the output.To be frank i want the code of the program.Plz help if u can
@saandeep-sreerambatla-hWHU1M • Jul 13, 2009
Please post clear question, post what you have tried so far such taht we can guide you..
#include<stdio.h>
#include<conio.h>
int main()
int i=0,j=0;
char a[10],b[10];
clrscr();
printf("enter the main string: ");
scanf("%s",a);
printf("\n enter the second string: ");
scanf("%s",b);
while(a!='\0')
if(a==b[j])
i++;
j++;}
else
j=0;
if(a==b[j])
j++;
i++;
else
printf("the given string is not substring");
printf("\n the given substring is present");
getch();
just check the program and tell me where i m going wrong -
This is my understanding..
Before the first if loop you have initialized i=0 and j=0.
If that condition fails again you have initialized j=0.
So if the first IF loop fails ..
Then the If loop in the else part will also fail for j=0.
This functionality is very easy by using for loops.
First take the main string into a[] , then substring into b[]
Use two for loops and you will get the answer. -
i have initialized j=0 again after the if loop fails coz the string might appear at any position of the second string like e.g we have to find whether the string "comp" is a substring of "mech & comp".so after the condition fails the second string is again ready to be checked from first while the counter of second goes on increasing.
@shalini-goel14-ASmC2J • Jul 13, 2009
Hi samaira,
int blen=0, k=0; //assign length of be to blen blen =strlen(b); //not sure while(a[i]!='\0') { if(a[i]==b[j]) { i++; j++; if(j==blen){ j=0; } } else { j=0; //if(a[i]==b[j]) //j++; i++; } else { printf("the given string is not substring"); } printf("\n the given substring is present"); } getch(); }Try this including b length's check in your program, if it works. Also, I think you can include a separate variable k in your program and initialize it to 0 and set its value as 1 when your check in if loop works and then at the end while printing message you can check if it is 1 then "matched" else "unmatched"
Thanks ! -
hey shalini thanks for ur help.:smile:
@Samaira If you program works then don't forget to post the complete working program here also.
Thanks ! -
@yogesh-dhiman-KMW24I • Jul 23, 2009
//Without using Functions.
#include(stdio.h) // place this '<' & '>' instead of '(' & ')' before stdio.h
#include(string.h)
void main( )
char st[20],sub[10],temp[10];
int pos, i, j;
clrscr( );
printf("Enter the main string:");
gets(st);
printf("\nEnter the substring to insert:");
gets(sub);
printf("Enter the index position:");
scanf("%d",&pos);
if(pos<=strlen(st)) {
for(i=0;i<=strlen(st);i++) {
if(i==pos)
for(j=0;st!='\0';j++) // to store the 'st' to 'temp' from given position.
temp[j]=st;
i++;
temp[j]='\0';
i=pos;
for(j=0;sub[j]!='\0';j++) // to insert a sub-str to main string.
st=sub[j];
i++;
for(j=0;temp[j]!='\0';j++) // Lastly to insert the 'temp' to 'st' after sub-str.
st=temp[j];
i++;
st='\0';
printf("\nAfter adding the sub-string: %s",st);
else
printf("\nSorry, it is not possible to insert a substring in that position.");
getch();
@jkr0103-AXiXHm • Jul 5, 2015
[HASHTAG]#include[/HASHTAG] <iostream> using namespace std; int main() { char a[] = {"Hanuman"}; char b[] = {"Hanuu"}; int i = 0, j = 0; while(a[I]!='\0') { if(a[I]==b[j]) { j++; if (b[j] == '\0') break; } else { i = i-j; j = 0; } i++; } if(b[j] == '\0') { cout << "substring exists\n"; } else { cout << "substring does not exists\n"; } return 0; }[/I][/I]
