Anybody knows 230VAC & 440VDC high power layout design?
umashankar.s
@umashankars-e0XF3M Oct 27, 2024
Hi
Anybody having exposure to 230AC and 440 DC layout design include motor, controller or drives design
how can we implement this high power design in layout?
any special considerations need to make or constraints do?
how u can route the phase and neutral of input power in board?
does it only thro wire and not thro pcb traces?
let me know
  • umashankar.s
    @umashankars-e0XF3M Jun 26, 2008
    Re: anybody know 230VAC&440VDC high power layout design?
    reply me to <snipped> also....
    @thebigk Jun 26, 2008
    Umashankar - go easy on posts! It takes time to get replies from members.
    We request that all discussions should happen on CE Forums - because each discussion benefits other CEans as well.
  • sauravgoswami
    @sauravgoswami-UAfTlI Jun 30, 2008
    Hmmm tats quite a long query!!..buddy,wat exactly you need and wath are u doing with project??
  • umashankar.s
    @umashankars-e0XF3M Jun 30, 2008
    simply my question is...
    what are the pcb layout methods and regulations for 230VAC or 400V DC in electric drives application?
  • umashankar.s
    As per latest technology, the two modules power as well as controller module combined into a single board. So what are the considerations need to follow in layout to avoid cross talk, EMI and heating effects... due to high power section to low power constroller section
    Is there any regulations applicable for these type of products like FCC, EN or UL certificaions?
    These products are used in home, commercial & industrial motion control..
    i think now ur clear on question...
  • sauravgoswami
    @sauravgoswami-UAfTlI Jul 1, 2008
    Well i think it is for a project,wat is ur project all about!!!certifications are important professional use..
  • umashankar.s
    @umashankars-e0XF3M Jul 1, 2008
    can you pls tell if you have an idea about 230V AC & 400Vdc...😁
  • umashankar.s
    ok...
    i got few thngs from net and that i share with u
    <a href="https://www.smps.us/layout.html" target="_blank" rel="nofollow noopener noreferrer">PCB Layout Guidelines and Tips</a>
  • KINETIC_JOULES
    @kinetic-joules-Qk9kmk Jul 2, 2008
    Your questions confuse me!
