@gohm-F3UUpP • Sep 7, 2008
They are simply horizontaly opposed piston engines most notablly used as twins by BMW in motorcycles, though they have had other uses (aircraft) and other manufactures. What specifics were you looking for?
mdronsubbs OP
@mdronsubbs-ovd1Y0 • Sep 8, 2008
i just heard about them somewher.....so just wanted to know what they are......can u pls povide with more information
@gohm-F3UUpP • Sep 10, 2008
What specifically are you looking for? Other than cylinder placement they are standard internal combustion engines. Think of it like a 90 degree v engine "opened" fully to 180. In motorcycles they help lower the center of gravity (at the slight cost of lean angle). If it is air cooled, the engine will run cooler than a typical v formation. They can also produce lateral torque movement (only noticed when stationary) This boxer engine design lends itself well to motorcycles and airplanes due to the shape of the motor.
