Answer the Electronics problem
selvaece2004
@selvaece2004-PrRKQW • Oct 26, 2024
1) Two lamps of 200W,200V and 100W,220V are connected in series across 220V supply.The ratio of current through theem will be
i) 1:2 ii)1:1 iii)2:1 iv)1:4
2)Two heaters,rated at 1000W,250V each are connected in series across a 250V,50Hz ac mains.Total power drawn from the supply would be
i) 1000W ii)500W iii)250W iv)2000W
3)A 200W,230V lamp is connected across 115V supply.The lamp will draw power
i)slightly more than 50w ii) less than 50W iii)50W iv)none of these
4)In two parallel conducting plates,each of area a and having charge density p,the force of attraction between them will be
i) (p^2*A^3)/(2*effsalan) ii)(e^2*A)/(2*effsalan) iii)p^2/(2*effsalan)
iv)p^2/2
  • reachrkata
    @reachrkata-FOcqhH Oct 31, 2009
    1) 1:1
    2) 2000W
    3) 50W
    4) (1/4*Pi*Epsilon)(p^2*a^2/d^2) - None of the choices.
    - Karthik
  • selvaece2004
    @selvaece2004-PrRKQW Oct 31, 2009
    But they gave answer for
    1) 1:2
    2) 500W
    3) slightly more 50W
    4) i
  • reachrkata
    @reachrkata-FOcqhH Nov 1, 2009
    1) I totally disagree with them. When you connect two loads in series, the current through them is always the same. WHATEVER YOU DO !!!😒
    2) Correct. I stand corrected, it is 500W. Thats because, the both are rated 250V,1000W. So when you apply 250V to both, they get half the voltage, which means they give only 1/4 the power. In total it is 500W.
    3) Same logic as above. If you give half the voltage, you will get 1/4 the power.
    4) Dont know how? Can you get the explanation too.
    - Karthik
  • BigOhm
    @bigohm-DhkHld Nov 2, 2009
    (1) is 1:1 as reachrkata clearly stated.
    (2) has no correct answer. Heaters are non-Ohmic.
    (3)has no correct answer. Lamps are also non-Ohmic
    (4) has no correct answer listed. The question is very poorly stated.
  • reachrkata
    @reachrkata-FOcqhH Nov 6, 2009
    Hey Big Ohm,
    All electrical devices are Ohmic in a way. The heating element in the heater is Ohmic and so is a lamp.
    -Karthik
  • BigOhm
    @bigohm-DhkHld Nov 6, 2009
    reachrkataHey Big Ohm,
    -Karthik
    Only if you can figure out how to run them at constant temperature (kinda defeats the purpose of a space heater, though 😔).
  • reachrkata
    @reachrkata-FOcqhH Nov 11, 2009
    Of course, based on the temperature the Ohmic value would vary.
    But the device remains Ohmic nevertheless !😉
    -Karthik
  • BigOhm
    @bigohm-DhkHld Nov 11, 2009
    The game is not worth the candle. You may indeed call such an effect Ohmic when corrected for temperature. I may equally well call it non-Ohmic. There is no bright line separating the cases. Nonetheless, whatever we call the effect, the resistance of a hot lamp cannot be measured cold.
  • risahe
    @risahe-CWscyd Nov 29, 2009
    I think this is not a very diffcult problem, you should think is by yourself.
  • omm87
    @omm87-YCi7t7 Oct 27, 2015
    there is a simple formulation given by power to calculate the consumption....
    also,
    [​IMG]
    [​IMG]
    and solve it..................by your requirement
