ACCURATE PREDICTION OF THE FUTURE;CAN EINSTEIN'S THEORY BE PROVEN?
Henri
@henri-7eYVw8 โ€ข Oct 26, 2024
Einstein died trying to prove that the future could be foretold accurately since electrons and sub-atomic particles that make up matter moved in specific velocity and direction.Once the two were considered,it would have been possible hence to predict the change in space occupied by these particles and thus the future.Quantam mechanics disputes this,saying by just observing the particles,their velocity and direction changes.Hence were variables and not constants...apparently all his theories,the theory of relativity inclusive,set out to have strong basis...Was Einstein right that the future could be calculated?
  • Jeffrey Arulraj
    @jeffrey-xA7lUP • Oct 10, 2012
    It will be volumes detailed report on all of Einstein's work are available in CE
    PS: mods do tag that thread that has all of EInstein's hard work here pls
  • Henri
    @henri-7eYVw8 • Oct 10, 2012
    jeffrey samuelIt will be volumes detailed report on all of Einstein's work are available in CE
    Jeffrey,,i don't follow...kindly elaborate
  • Jeffrey Arulraj
    There is a too deep level of scientific instance in Einstein's work you will find that almost all his works are related to the field of Quanta and
    If you are to identify a quanta and predict its future it is easy under this condition it moves in 1 D closed object
    If the word closed is removed being both small and random in nature due to surrounding effect it becomes more complex
    Next to further increase the complexity comes the 3 D box with limits here three velocities and the other objects in this region becomes more significant here
    Next this is further complicated by the fact that there is no exactly closed system in this world and all are open so objects future cannot be easily predicted
    And so I asked the MODs to tag in a thread which has all of his works in this forum
  • Henri
    FIRSTLY
    jeffrey samuelThere is a too deep level of scientific instance in Einstein's work you will find that almost all his works are related to the field of Quanta and
  • Jeffrey Arulraj
    HenriFIRSTLY
    I need more info to suggest here pal
  • Henri
    firstly,i think a publication of all Einstein's work would be great i they will do that...i think Jeffrey,you are looking at it from a wrong perspective.Do not look at prediction in terms of the world in 3 D kind of way..Look at prediction in terms of an event,,,,an event is basically made up of three components...ACTION,TIME and SPACE....from this angle,,you get to see that Einstein saw time and space as constants,,,these actions would require matter which was also influenced by einsten's two constants,,,so we basically have two aspects of time and one aspect of space where all this event occurs..Yes,,all of Einstein's wok is based on quonta..its because of him that branch of science was introduced..apparently it beacame his doom
  • Jeffrey Arulraj
    You will have to see that if predicting is difficult for a quanta then for a real time incident it becomes more complex and more harder but i doubt whether it is feasible now with our current tech
