Title: What Are the Biggest Challenges in Maintaining ESP32-Based IoT Devices After Deployment?
Vaani Jain
@vaanij
Published: Nov 24, 2026
ESP32 has become a popular choice for IoT projects, from smart home automation and environmental monitoring to industrial sensor networks. Getting a prototype working on the bench is usually manageable, but maintaining devices once they are installed at remote locations is a different challenge.
One area I find particularly interesting is firmware maintenance.
Imagine deploying 50 or 100 ESP32-based sensor nodes across different locations. A few months later, you discover a bug or need to add a new feature. Updating every device manually through USB is not a practical option.
This is where Over-the-Air (OTA) updates become useful.
ESP-IDF provides OTA functionality using two application partitions. The new firmware is downloaded to the inactive partition, and the bootloader can switch to it after the update. Rollback support also helps recover if the new firmware fails during its first boot.
However, there are several engineering considerations:
  • How much flash memory should be reserved for OTA partitions?
  • What happens if the Wi-Fi connection drops during a firmware download?
  • How do you verify that the new firmware is actually working before accepting it?
  • Is HTTPS certificate verification sufficient, or should firmware signing and Secure Boot also be implemented?
  • How do you manage firmware versions across multiple deployed devices?
One of its guides explains how to set up ESP32 OTA updates using ESP-IDF, covering partition configuration, HTTPS firmware downloads, version checking, rollback protection and Secure Boot.
Here's the guide for anyone interested in the implementation:
How to Set Up ESP32 OTA Updates with ESP-IDF
For those who have worked on ESP32-based products, what OTA update strategy have you found reliable?
Do you implement the complete rollback and firmware security mechanism from the beginning, or start with basic OTA functionality and add protection as the project moves towards production?
I'd particularly like to hear from engineers working on remotely deployed IoT devices. What problems have you encountered with firmware updates, and how did you solve them?
