Job opportunities in Software Testing for B.Com?
Divya Chella
@wHezkMx
Published: Oct 20, 2024
Updated: Apr 3, 2026
Views: 452.2K
I'm Experienced in Non IT background, but the enthusiasm to work in Software Testing makes me to again ask this question, Shall the recruitment management consider me to give a chance to work in SDLC department my background is Bcom ?
    @thebigk • Oct 22, 2024
    There definitely are opportunities for professionals with non-engineering background in the software testing / IT.
    Software testing job will require you some prior knowledge of how testing works in the software industry. I recommend exploring the multiple segments that exist in the industry, build your specialisation in one or two before applying to job.
    If you dedicate your time to it, you should be gain sufficient expertise within 3-4 months. Here are a few domains that I suggest:
    1. Database testing
    2. Stress testing
    3. Web App testing
    4. UI testing
    5. Hardware testing
    6. Device-driver testing
    Without prior experience, I suggest that you should aim for building some experience in manual testing. Manual testing will give you a clear idea of the real-world testing.
    The second step would be to build some expertise in automation testing. Selenium with Python or Selenium with Java are heavily in demand in India. If you can join any reputed institute - you should be able to gain some experience fast.
    I also recommend opting for basic certification like ISTQB. It will give you an edge in the job market.
    I hope this helps. If you have follow-up questions, ask below.
  • Aniruddha Pimpalkhare
    @zv6jias • Oct 30, 2024
    Great suggestions Kaustubh.
    If Divya can clear the second step and finds coding interesting then she should definitely try third step: become a software developer. I have worked with a couple of software developers with B Com background. Note that this is not easy, there is a lot of hard work involved. You have to catch up with IT/CS graduates who have a head start.
    Alternate third step: Another opportunity is Business Analysist in Finance domain in case she finds second step tough.
  • Jackson
    @EkynDZf • Mar 19, 2025
    Recruiters may consider your enthusiasm, transferable skills, and willingness to learn when evaluating your application for a software testing role. Highlight your analytical skills, attention to detail, and problem-solving abilities to strengthen your case for consideration.
  • Rohan Babu
    @tidy-bucket • Apr 3, 2026
