With Bluewire Smart Bluetooth Call Recorder Record Voice & VoIP Calls Easily
Senss Technologies have concocted a hardware solution for two way call recording called Bluewire. The Bluewire Bluetooth call recorder is not just a standalone Bluetooth headset but it also allows you to use your existing Bluetooth headset with it. It even manages to work with your in-car Bluetooth system as it has been made to record any voice calls, normal or VoIP, that is made on your Android or iOS smartphone. Yes, it will even record the calls that you make on your handset without any accessories. Unlike other call recording apps that store calls on the mobile device, it stores the recordings on its 16 GB internal memory that can be easily transferred to your mobile device using NFC, provided you have installed the companion Android or iOS app.
The makers of Bluewire have added a few other bells and whistles to it as well. Starting with a rudimentary flashlight and going as advanced as wireless charging. The Bluewire headset can also be used to find your smartphone and vice versa. The Bluewire can serve as a burglar alarm and as a walkie-talkie between your phone and device. You can use the Bluewire to record voice memos of up to five minutes. The files stored on Bluewire can be transferred directly to a PC via USB. Coming to the technical specifications of Bluewire, it is powered by a 3.7V 280mAh battery that offers talk time of 4 hours, recording time of 2.5 hours and standby time of 4 hours. The Bluewire can be charged completely in two hours and if you are running short of time a quick charge of 45 minutes can give the Bluewire half of its battery life.
The team is currently seeking funding on Indiegogo for mass producing Bluewire. Within a day of launch it has crossed half of its funding goal of $40,000 and with a month to go it is sure to achieve that goal. The Bluewire is pricey though, early adopters are getting it at prices as low as $149 (9,136 INR) but the retail price is expected to be $269 (16,493 INR). To know more about Bluewire you can watch the promotional video below or head over to the source link that follows.
Source: <a href="https://www.indiegogo.com/projects/bluewire-hands-free-call-recording" target="_blank" rel="nofollow noopener noreferrer">BlueCarbon: Bluetooth cellphone calls recorder. | Indiegogo</a>, #-Link-Snipped-# via <a href="https://techcrunch.com/2015/01/27/the-bluewire-is-a-bluetooth-headset-that-can-record-your-calls/" target="_blank" rel="nofollow noopener noreferrer">The Bluewire Is A Bluetooth Headset That Can Record Your Calls • TechCrunch</a>
