    @ramani-VR4O43 • Feb 16, 2016
    Turning, boring and polishing cylinders (pistons and cylinders) easy on conventional machines. Also being symmetric wear is more uniformly distributed. Axial alignment is automatic for cylinders.
  • Jeya seelan
    @jeya-kHwc6V • Feb 17, 2016
    cylindrical shapes are ideal because they have better capacity to resist internal pressure. They don't deform under pressure when subjected to radial forces by the fluid. Moreover, there is no shear component while in all other shapes you'll have a shear force which will tend to deform the shape.
  • silver123
    @silver123-vE0qz7 • Feb 19, 2016
    Cylindrical shapes are ideal because they have better capacity to resist internal pressure. They don't deform under pressure when subjected to radial forces by the fluid.
  • Sanjay Rawat
    @sanjay-myptMh • Feb 21, 2016
    kaliyul rahimananswer please............
    Cylindrical shape is with maximum volume at minimum surface area resulting minimum friction.
  • SIVAKUMARG
    @sivakumarg-lfmInK • Feb 21, 2016
    No shear force .. hence no deforming in that shape
