@thebigk • Dec 12, 2016
SAYED SABEERAC voltage only step up or step down. it is not possible to DC .what is the reason? if it is possible how?
A Boost Converter does step up DC Voltage. Here's a DIY Boost Converter -
@jay-l5YtcX • Dec 13, 2016
In order for voltage to be 'stepped up/down' there needs to be a cyclical change or fluctuation/oscillation in the voltage.
If the DC voltage has that cyclical change, it can be stepped up/down.
For example, think about a DC voltage that varies between 100 vdc to 1 vdc at 60 cycles/second. A DC voltage like that can be stepped up/down by a simple transformer as is commonly used for AC power.
Jay Kosta
Endwell NY USA -
SAYED SABEER OP
@sayed-sabeer-OrDs5D • Dec 13, 2016
Jay KostaIn order for voltage to be 'stepped up/down' there needs to be a cyclical change or fluctuation/oscillation in the voltage.
Jay Kosta
Endwell NY USAhow it is possible? which component to use step up the DC voltage
@jay-l5YtcX • Dec 14, 2016
What are the specifications for the input and output DC voltages? There might be commercial devices available that do what you need - google dc voltage converter.
A simple DIY example would be a converter device that plugs into the 12VDC supply in an automobile and has output of household AC voltage. Then plug into that a computer/electronics power supply that produces 24VDC or 6VDC.
Jay Kosta
Endwell NY USA
