What type of motors are used in sewing machines & what's the max torque do they have?
zaveri
@zaveri-5TD6Sk โ€ข Oct 20, 2024
hey guys does anyone here know what type of motors are used in sewing machines and the maximum torque that they deliver.(just an approximate value).
Besides this does anyone know the maximum torque delivered by ceiling fan motors and pump motors ? (numerical values).
  • pratap singh, upendra
    @pratap-singh-6xlmve • Jan 2, 2013
    as far as I know the commercial sewing machines that are available in the market are necessarily constant speed motors that are designed to operate at different but fixed speed and which do not require a very high starting torque...
    these facts make dc shunt motors to be the most obvious choice for this applications
  • zaveri
    @zaveri-5TD6Sk • Jan 2, 2013
    Thanks buddy.
    But then can you tell me an approximate value for the value of maximum torque in Nm.
    are dc shunt motors used for this ? since sewing machines are used domestically then won't they be using an AC motor or induction motor to run on Ac current ?
    by the way what about the torque of ceiling fan motors.
    @pratap-singh-6xlmve • Jan 3, 2013
    u see in most of the cases, the efficiency of the ac shunt motor is poor compared to its dc counterpart. More ever as far as different motors are concerned they cannot be used because there has to be a definite and fixed speed for performing one of the specific task. Because this speed must not change as the load varies, a shunt motor remains as obvious choice.
    recently there has been advancement in the design of various induction motors that can substitute dc shunt motors with regards to this operation....
    as far as torque is concerned, it varies depending upon the design, constructional parameters etc. and two machines working in the same manufacturing unit can have different torque specifications....
  • zaveri
    @zaveri-5TD6Sk • Jan 6, 2013
    Thank you guys.
    now can help me obtain data sheets of such motors from the net. i tried it myself and could find only one.
    @pratap-singh-6xlmve • Jan 6, 2013
    i suppose you cannot get the datasheets via internet. You have to necessarily visit the company concerned for further assistance or a showroom etc. Only the manufacturers or vendors can provide you with a legitimate datasheet
  • lal
    lal
    @lal-R60Xjx • Jan 6, 2013
    I think, universal motors are used in sewing machines. Like in a mixer grinder. They are essentially series motors able to provide high RPM and good torque output. Will check back and reply. I pretty much believe it is not a DC shunt motor.
  • zaveri
    maybe you are very close. i obtained a datasheet of a motor manufactured by TULLU. it is a AC/DC motor, which means it is universal, right. and besides i have seen a motor being used for a gyroscope, which provided very high speed (rpm) and torque to the flywheel, so hence its got to be a series wound motor.
  • lal
    lal
    Browsed a bit and found it to be universal motors which are used mostly in household sewing machines. Here is a link (isn't much technical though): #-Link-Snipped-#
    Yeah, AC/DC means it is a universal motor. It is designed to work on both AC and DC supply. Being a series motor, it will be able to provide enough torque and high rpm.
    The biggest limitation in using DC motors is that, our domestic power supply is in AC mode and for a DC motor to be used, an extra step of power conversion comes in between (rectification). But, a DC motor provides precise speed control when compared to other types. But that isn't needed for domestic applications.
    Even though a shunt motor exhibits amazing speed regulation, in normal use, a domestic sewing machine motor will not be operated continuously. It will be frequently started and stopped. So speed regulation is insignificant. With less torque, it might not work as desired on tough clothes too. Same is the case of an induction motor - low torque and tougher speed control.
  • Samanth Batchu
    @samanth-z91ff9 • Sep 13, 2018
    If we use this motor what kind of energy produce
