@zaveri-5TD6Sk • Jul 23, 2012
Slip gauges are high-precision measuring instruments, used for testing, inspection along with comparators.
Wringing is nothing, but removing the atmospheric air between two mating surfaces of any two gauge blocks, so that the blocks stick to each other due to vaccum.
to do this, hold the two blocks edge-to -edge, and gently push one of the blocks inside so as to make it sit on the other block, completely. -
@white-hat-RTFca6 • Jul 23, 2012
Kedar Malwadkarwhat is Wringing of slip guages?
You should check out TRIMOS.Google it to find out more.
Measurement labs do not use slip gauges any more,for high precision measurements trimos is used. -
@kedar-crbktt • Jul 24, 2012
white_hatYou should check out TRIMOS.Google it to find out more.
Measurement labs do not use slip gauges any more,for high precision measurements trimos is used.might be, but it's in our syllabus so i need to read that!!!๐๐๐
Thanks for the help guys!
