What is the use of Thinner and Hardener in paint?
Ankush Sharma
@ankush-FCZUYR โ€ข Oct 27, 2024
Hello Everyone, We all know that, before painting we have to add thinner and hardener in paint.
But i want to know few things.
  1. Why there is a need of thinner in paint? Usually, the simple answer for this question is to make the paint thin. But, if this is the case then why don't paint manufacturing company's just manufacture the paints thin at first point? So, there must be some technical reason to add thinner in paint! what's that?
  2. Why we add hardener in paint? Even i read somewhere that its not compulsory to add hardener always. So, first thing that what is the use of it in paint? and if it's true that it is not compulsory in all cases then how can we come to know?
Would really appreciate if someone could answer this in detail.
Answer:
These are excellent questions. Understanding the functions of paint additives like thinner and hardener can enhance your knowledge about the painting process, whether you're a hobbyist or a professional. I will explain each in detail.
The use of thinner in paint:
Paint thinner is primarily used to adjust the viscosity, or thickness, of paint to make it easier to apply.
This can be especially helpful when working with oil-based paints, which tend to be thicker than water-based or latex paints.
Thinner also aids in cleaning brushes and other equipment used in the painting process.
Regarding your question about why paint manufacturers don't simply produce already thinned paints, there are a few reasons:
  1. Paint Quality: Paints are typically sold in a thicker state to maintain the quality of the pigment and binding agent. When paint is thinned, it can lose some of its adhesive quality, meaning it may not stick to surfaces as well or provide as robust coverage. Manufacturers provide paint in its most potent and versatile state, and the user can thin it based on the specific requirements of their project.
  2. Versatility: Different painting tasks require different levels of paint viscosity. For instance, painting a large wall with a roller might require thicker paint for better coverage, while painting intricate details or using a spray gun would need thinner paint. Manufacturers can't anticipate every application, so they provide the paint in a more universal state, and the painter adjusts it according to their need.
  3. Shelf Life: Thicker paint has a longer shelf life because the key components (pigment, binder, etc.) are more stable in this state. If the paint were pre-thinned, these components could separate over time, reducing the paint's quality and effectiveness.
The use of hardener in paint:
Paint hardeners, also known as catalysts, are used to promote faster drying and to enhance the durability of the paint once it has dried.
They're most commonly used with two-part paints (like epoxy paints or polyurethane paints), where a base paint is mixed with a hardener before application.
Hardener causes a chemical reaction with the paint that makes it cure to a harder finish than would be possible if the paint dried or cured on its own.
This increases the paint's resistance to scratches, chemical damage, UV damage, and general wear and tear.
It's particularly useful in high-traffic areas or when painting objects that will be exposed to harsh conditions, like boats or floors.
As for whether a hardener is always necessary, this depends on the type of paint and the desired outcome:
  1. Not all paints require a hardener. For example, most latex and oil-based paints for home use do not require hardeners. They cure through the process of evaporation of the solvents within them.
  2. The paint will tell you. If a hardener is required, it will be stated on the paint's instructions. Two-part paints will always require a hardener. If you're unsure, it's best to ask a paint professional.
  3. Consider the use-case. Even when not explicitly required, a hardener can be useful if you're looking for a particularly durable, hard finish. But remember, using a hardener might make the paint less flexible, which could be a problem if the painted object is subjected to movement or temperature changes.
To summarize, both thinner and hardener are used to modify the properties of the paint to suit specific applications.
Thinner adjusts the paint's viscosity and facilitates its application, while hardener accelerates the drying process and improves the final durability of the paint job.
The need for each depends on the type of paint and the specifics of the painting task.
    @ramani-VR4O43 • Oct 11, 2016
    1. Thinning the paint is a point of use issue. Adding thinner to paint increases bulk, packing and transportation costs. Customising the spreadability at the user end is lost. Thinners are a fire hazard, which may add to transportation and warehousing problems.
    2. Hardeners are needed only for two component type of coatings like epoxies that cross link. If a particular paint needs it the manufacturer supplies it. Since there is a pot life after adding the hardener, this has to be necessarily done at use.
  • Ankush Sharma
    @ankush-FCZUYR • Oct 13, 2016
    A.V.Ramani1. Thinning the paint is a point of use issue. Adding thinner to paint increases bulk, packing and transportation costs. Customising the spreadability at the user end is lost. Thinners are a fire hazard, which may add to transportation and warehousing problems.
    Ok, Thanks for information.
    You gave all the information regarding at what time thinner and hardener is added and why it is added at that particular time.
    But one more thing i want to know, Why there is a need to add thinner and hardener(in case if it is specified by manufacturer) in paint? Simply, why these are required in paint? Do, they increase the life or finishing of paint( because I don't know for what purpose these are) or may be any other technical reason?
    @ramani-VR4O43 • Oct 13, 2016
    Thinner does what its name implies. It reduces the viscosity of the paint. Depending on the method of application (Brushing, Roller etc.) and thickness of the coat the user can adjust the consistency to suit the demands of the job.
    Some paints have a chemistry that requires cross linking between two types of molecules. One will be the resin in the bulk paint. The other molecule is in the hardener. When the paint is mixed with the hardener the cross-linking chemical reaction begins. That is why a pot life is specified. If you wait too long after adding the hardener the paint will set and not usable.
    Some basics about non cross-linked paints here:
    <a href="https://gaganshreeagarwal.webs.com/painttechnologybasics.htm" target="_blank" rel="nofollow noopener noreferrer">Paint Technology Basics - paint technology</a>
    This discussion on hardeners may help you:
  • Raghu Vamshi
    @raghu-zKvp2k • Mar 29, 2019
    What if I use a wrong hardner with a paint??
