What is dc component for digital signals?
isha123
@isha123-DDef7a • Oct 26, 2024
I read that when voltage level is constant for a while,spectrum creates very low frequencies.How are voltage levels related to frequency?
  • pratap singh, upendra
    @pratap-singh-6xlmve Aug 27, 2015
    in what context are you asking this question...
    Could you give me some more detail?
  • Vishal Sharma
    @vishal-pysGmK Aug 27, 2015
    #-Link-Snipped-# #-Link-Snipped-# Is this question in the right section?
    @abrakadabra Aug 27, 2015
    Vishal0203#-Link-Snipped-# #-Link-Snipped-# Is this question in the right section?
    Moved to Electrical. 👍
    @pratap-singh-6xlmve Aug 28, 2015
    "voltage level is constant for a while,spectrum creates very low frequencies"
    Although it may look that voltage has reached a steady state, it is never the case. In fact any practical dc voltage will always have some ac component (such as electronic noise etc.). The frequency of these noise components appears in the spectrum of a dc voltage signal.
  • Jeffrey Arulraj
    @jeffrey-xA7lUP Sep 2, 2015
    isha123I read that when voltage level is constant for a while,spectrum creates very low frequencies.How are voltage levels related to frequency?
    Actually Voltage is defined as Rate of change of Electric Field variation in a Medium.
    So when a signal has a constant Voltage Value, then you should know there is no significant variation in Electric field as well(Integral of Voltage is Electric field).
    With this idea adding to the fact that most signals are EM in nature results in generating very low frequency signals.
    P.S: DC Component of a signal is different from the above mentioned answer. Be more specific in your question next time.
    Have fun
  • isha123
    @isha123-DDef7a Sep 4, 2015
    #-Link-Snipped-# thankyou so much
  • isha123
    #-Link-Snipped-# #-Link-Snipped-# I actually came across this while reading digital data transmission in computer networks.
  • Vishal Sharma
    @vishal-pysGmK Sep 4, 2015
    isha123#-Link-Snipped-# #-Link-Snipped-# I actually came across this while reading digital data transmission in computer networks.
    I don't see that in the question.
    Anyway, as samuel said, be more specific next time!
