Ways of improving the stability of an object
From theory we know lower Centre of Gravity and a wider base improves stability. My question is, do you know other ways of improving the stability of an object. I will put forth the application in question:
A trolley is to be used to transport a display panel (with guages, flowmeter etc) on fairly rough terrain (gravel). The panel must be bolted down on the trolley.
The problem i have is that the panel box is slim and tall and most of the weight is distributed at the top. On a rough terrain the tall panel will be subject to moments which can cause the entire apparatus to topple over.
How do I go about making this system more stable?
Note: I cant make the base too wide (Maneuverability)
![[โIMG]](proxy.php?image=http%3A%2F%2Fdl.dropbox.com%2Fu%2F27178479%2Fpg1%25281%2529.jpeg&hash=51d74c44933d0dc14bff2dd23440a747)
