  • Watts, KW, Volts, Amps Relation
    aspardeshi
    aspardeshi
    @aspardeshi-0Rc3EE
    Updated: Oct 26, 2024
    Views: 1.0K
    What is 10 KW generator, I get confused if it is delivering power at 215 volts 😔, and producing voltage at 1200 volts internally 😔 😔 and actually company rated 10 KW. Please help me solve this internal mess.
  • Saandeep Sreerambatla
    MemberJan 17, 2010
    Generally power is measured in Watts.
    So power P = VICos@
    V = Voltage in Volts , I = Current in Amps. Cos@ = power factor.
    Be more clear for a clear answer.
  • sauravgoswami
    MemberJan 18, 2010
    KW means x 1000 Watts = Current x Voltage,and cos@ as well but it is normally 1, for AC power.
  • aspardeshi
    MemberJan 18, 2010
    Well My problem is that when a person design a generator, he is not sure how much power output it will give, like for example I have seen generators which design 1200 volts or 240 volts also, so how to calculate the power requirement of my home or factory and make the generator suitable for it. how to adjust volts and amps to make it suitable for every device. Please help. Thanks in advance.
  • aspardeshi
    MemberJan 18, 2010
    Well My problem is that when a person design a generator, he is not sure how much power output it will give, like for example I have seen generators which design 1200 volts or 240 volts also, so how to calculate the power requirement of my home or factory and make the generator suitable for it. how to adjust volts and amps to make it suitable for every device. Please help. Secondly if my factory power requirement is 150 kw then can i combine the generators together to match the output requirement. Thanks in advance.
  • aspardeshi
    MemberJan 18, 2010
    Well My problem is that when a person design a generator, he is not sure how much power output it will give, like for example I have seen generators which design 1200 volts or 240 volts also, so how to calculate the power requirement of my home or factory and make the generator suitable for it. how to adjust volts and amps to make it suitable for every device. Please help. Secondly if my factory power requirement is 150 kw then can i combine the generators together to match the output requirement. Thanks in advance. 😒
    MemberJan 18, 2010
    sauravgoswami
    Hey Saurav I think you got confused buddy , since if power factor is generally 1 then there will be very less losses but that's not the case !!
