yeah i wanted to know if i can do project to trace some vehicles which are lost.... is this already tried out or implemented anywhere... could u pls let me know if any body else has thought about it or discussed it....caun u pls suggest me some ideas...pls reply soon0
Member • Aug 28, 2012
read about GPS systems
vehicle trackingAre you sure? This action cannot be undone. -
Member • Aug 29, 2012
there must a trakker on the care and a receiver in your hand that should help you in short range in longer ranges satelite enabled GPS suits you a lotAre you sure? This action cannot be undone. -
Administrator • Aug 29, 2012
You can practically trace anything that's coupled to a GPS. The Global Positioning Systems can track accurately up to a few meters of distance and have been in service for a long time now. But that does not mean you can't attempt it again. It'd be a great learning for sure.shruthipyeah i wanted to know if i can do project to trace some vehicles which are lost.... is this already tried out or implemented anywhere... could u pls let me know if any body else has thought about it or discussed it....caun u pls suggest me some ideas...pls reply soon
If you really want to come up with something innovative; find what can be improved in the existing system. Is there a problem in existing tracking systems that you can fix? That'd make you do something 'new' and 'innovative'.Are you sure? This action cannot be undone. -
signal from transmitter and reciever should be very fast... to track it as soon as possible...Are you sure? This action cannot be undone. -
why should it benaveeesignal from transmitter and reciever should be very fast... to track it as soon as possible...
what is a fast signal any wayAre you sure? This action cannot be undone. -
to overcome the signal loss from the reciever end.... it will be disadvantage of that exitsting device.. :Are you sure? This action cannot be undone. -
losses are a concern in any transmission now a days digital transmission is becoming more efficient but for a simple ckt there is no need of that but the main concern is the range and the quality of the deviceAre you sure? This action cannot be undone. -
one question range of the device... depends on wht??? ....Are you sure? This action cannot be undone. -
the signal strength of the transmitter and also the method of transmission it use if it is line of sight and some lower methods then they have short rangeAre you sure? This action cannot be undone. -
what is multivibrator....is it a switching element ???The_Big_KYou can practically trace anything that's coupled to a GPS. The Global Positioning Systems can track accurately up to a few meters of distance and have been in service for a long time now. But that does not mean you can't attempt it again. It'd be a great learning for sure.
so sensors(manufacture) are not major factor for signall lossing ?????jeffrey samuelthe signal strength of the transmitter and also the method of transmission it use if it is line of sight and some lower methods then they have short rangeAre you sure? This action cannot be undone. -
the mode in which the signal is transmitted accounts for losses not the sensors alone they account only a fraction of the lossAre you sure? This action cannot be undone. -
In my opinion it solely depends on the speed(at which it is transmitted) of the signal and the strength of the signal..! Both must mutually co-exist..! Because if speed is low, signal strength deteriorates and if the strength is low no point at all....!naveeeone question range of the device... depends on wht??? ....
I dont understand this..! Even the slowest signal transmission happens at the wink of an eye..! 😀 It just leads to losses..! 😀naveeeto track it as soon as possible.Are you sure? This action cannot be undone. -
Member • Aug 30, 2012
yes my friend and the speed depends on the power given to the transmitter to transmit the signalsvinod1993In my opinion it solely depends on the speed(at which it is transmitted) of the signal and the strength of the signal..! Both must mutually co-exist..! Because if speed is low, signal strength deteriorates and if the strength is low no point at all....!Are you sure? This action cannot be undone.
