TORQUE CALCULATION ON A CIRCULAR DISC
A disc of dia 300 mm and thickness of 5 mm made of mild steel.It has to be rotated by a motor at a rpm of 100.The motor shaft is connected to the disc by a gear mechanism.The outer periphery of the disc is having a profile of gear teeth.Now my question is,
a)What is the required torque to rotate the disc?
b)What will be the calculation to determine the horse power of the said motor?
  • Ankush Sharma
    @ankush-FCZUYR • Oct 11, 2016
    Dear,
    According to me find the following calculations.
    Diameter(d)=300 mm
    Thick(t)= 5 mm
    RPM(N)=100
    Let, Y.S. of mild steel(Y)=250 N/mm^2
    Now ,Allowable Shear Stress(S)=Y*0.5 =250*0.5 =125 N/mm^2
    Let, F.O.S.(F)=2.5
    Therefore, Allowable Shear Stress=S/F =125/2.5 = 50 N/mm^2
    Also, Let Polar moment of Inertia is "J" and the Radius of shaft "R"(also the maximum distance from center)
    Now, the formula for torque is,
    Torque(T)= (J*S)/R
    Now, J= (3.14*d^4)/32
    = (3.14*300^4)/32
    = 794812500 mm^4
    Now, substitute all the values,
    T= (794812500*50)/150
    = 264937500 N-mm
    T = 265 KN-M
    Now, The formula for power required,
    Power(P) = T*W
    where, W= angular velocity
    Now, W= (2*3.14*N)/60
    = (2*3.14*100)/60
    = 10.5 RPS
    now substitute the values,
    P= (265*10.5)
    = 2774 KN-m/s
    P= 2774 KW
    Kindly note, If you don't consider the calculations correct then please don't use them.
  • PRADIP CHAKRABORTY
    @pradip-MzE4HZ • Oct 12, 2016
    PRAD CHAKRABORTYA disc of dia 300 mm and thickness of 5 mm made of mild steel.It has to be rotated by a motor at a rpm of 100.The motor shaft is connected to the disc by a gear mechanism.The outer periphery of the disc is having a profile of gear teeth.Now my question is,
    ---Sir,
    Please let me know how 150 has come while calculating the torque
    it might be the radius of the disc?
    PRAD CHAKRABORTYit might be the radius of the disc?
  • Ankush Sharma
    @ankush-FCZUYR • Oct 13, 2016
    PRAD CHAKRABORTY---Sir,
    Dear,
    150 is the radius(R) of disc.
    As your diameter is 300 mm, hence the radius is 150 mm.
    Also, Note that the value of the torque(265 KN-m) i get is actually the maximum torque you can apply on this particular disc and the value of power(2774 KW) i get the power required to produce 265 KN-m torque or in other words you can also say that 2774 KW power can be safely transmitted through this disc with some obvious deflection(by safely i means the shaft will not break but can deflect). SO, If you want the torque required to start the rotation then the calculations will be different.
    @pradip-MzE4HZ • Oct 13, 2016
    ok si
    r
    ok sir,
