Supercomputer gets super water-cooleda
I was just reading news on Web, came across the following news and thought would generate interest in CEan's to do something as innovative as this is. Posting the same:
Reference: #-Link-Snipped-#
Water as a coolant has the ability to capture heat about 4,000 times more efficiently than air, and its heat-transporting properties are also far superior. Chip-level cooling with a water temperature of approximately 60°C is sufficient to keep the chip at operating temperatures well below the maximally allowed 85°C. The high input temperature of the coolant results in an even higher-grade heat as an output, which in this case will be about 65°C.
The pipelines from the individual blades link to the larger network of the server rack, which in turn are connected to the main water transportation network. The water-cooled supercomputer will require about 10 litres of water for cooling, and a pump ensures a flow rate of roughly 30 litres per minute. The entire cooling system is a closed circuit: the cooling water is heated constantly by the chips and consequently cooled to the required temperature as it passes through a passive heat exchanger, thus delivering the removed heat directly to the heating system of the university in this experimental phase. This eliminates the need for today's energy-hungry chillers.
"Heat is a valuable commodity that we rely on and pay dearly for in our everyday lives. If we capture and transport the waste heat from the active components in a computer system as efficiently as possible, we can reuse it as a resource, thus saving energy and lowering carbon emissions. This project is a significant step towards energy-aware, emission-free computing and data centres," explained Bruno Michel, manager advanced thermal packaging at IBM's Zurich Research Laboratory.
-CB
![[IMG]](proxy.php?image=http%3A%2F%2Fimg196.imageshack.us%2Fimg196%2F1816%2Feetimesasia.jpg&hash=c8f39150c80cea0c1c63ba795083526c)
