Solar Wind Energy Tower: A Hybrid Solar-Wind Energy Technology Gets The Official Nod
The Solar Wind Downdraft Tower has been specifically built to work in hot and dry regions. The company chose the city of San Luis, Arizona because it has the ideal weather conditions needed by the tower to work. Its structure as you can see from the image above is comprised to a tall hollow cylinder with a water injection system at the top and a series of wind turbines at the bottom. To make the system work, water is fed to the towerâs injection system which then spreads it across the opening at the top in form of a thin mist. Owing to the hot conditions, the water evaporates and is absorbed by the dry air which has been heated by the sunâs rays. This causes the air inside the tower to be cooler, denser and heavier than the surrounding warm air. The heavier air then falls through the cylinder at speeds of up to 50 miles per hour. This fast air is then channelled through the wind turbines which then generate electricity. To help you understand the process better we have embedded a video demonstration by the company below.
Now the big question, how much electricity does the Tower actually produce? The company claims that under ideal conditions the Tower designed for the Arizona site has a production capacity on an hourly basis, of up to 1,250 megawatt hours. But if you put into account all year round varied weather conditions the average hourly output per day for sale to the grid for the entire year averages approximately 435 megawatt hours/hr.
After reading the article we are sure you might have many questions in mind, so why not pursue through <a href="https://www.solarwindenergytower.com/index.html" target="_blank" rel="nofollow noopener noreferrer">Website Not Avaiable</a> and its coverage on #-Link-Snipped-# before beginning a discussion in the comment section below.
