  • Solar Powered Submersible Pumps
    Updated: Oct 25, 2024
    Views: 1.1K
    I need to know all about SOLAR POWERED SUBMERSIBLE PUMPS. Please help.
    AdministratorJan 16, 2013
    MD. ABDUR RAKIB
    Have you tried searching on the Internet? Did you get any information from there? If yes, why not share it with us and ask where are you stuck? 😀
  • MD. ABDUR RAKIB
    MemberJan 16, 2013
    I only found some manufacturers brochure.
    The_Big_K
  • ISHAN TOPRE
    MemberJan 16, 2013
    MD. ABDUR RAKIB
    There is no such animal. A submersible pump has its own specifications The solar panel is an independent entity that has to be designed to suit the intended purpose. You are likely to succeed if you chose a standard pump and choose/design a suitable PV power pack to drive. I have seen a few installations in the remote tribal areas of the forests of Mysore, which are working well. However the PV panels are quite large and expensive.
  • MD. ABDUR RAKIB
    MemberJan 17, 2013
    bioramani
    Thanks a lot sir
    MD. ABDUR RAKIB
    Thanks a lot sir
    The pump can be powered by a DC motor. This will avoid an inverter and can be coupled directly to the panel. Even a battery can be avoided. In this case one is limited to pumping only at peak solar availability.
    Some friends of mine work for an established company called Jain Irrigation.
    You can get some info here:
  • Digambar Harishchandre
    MemberOct 6, 2015
    Hi guys, I am working in same field And we provides solutions in all solar applications like solar thermal, solar PV, solar pump, etc...
    As in solar pumping system, it's capacity depends upon ur end application, depth of bore well, etc.
    We can develop pumps with dc or ac power supply.
    And we can run it on dual mode like during day time on solar power and at night time on grid power also.
    Its a very good solution for remote access and in areas where very long and frequent power cuts.
    Its cost is around rs.1lac per hp.
