Shutdown someone's computer using ip
rariya
@rariya-9XDZcZ โ€ข Oct 26, 2024
open cmd and write there{ shutdown -i} it will open a menu in which u have to add ur desire ip address which u want to shutdown and select operating system reconfiguration then hit ok with some comment for warning..
    @anoop-kumar-GDGRCn • Jul 29, 2012
    You need to have same username and password with on both of computers with administrator privilege. ๐Ÿ˜€
    @thebigk • Jul 30, 2012
    As #-Link-Snipped-# said, you can't shutdown any machine without having proper access and privileges on the machine you're trying to shut down. Have you tried this on your own?
  • durga ch
    @durga-TpX3gO • Jul 30, 2012
    Is this some reverse feature of wakeonlan?/
    with wakeonlan feature a specific device can be started up over lan interface . It supposedly needs mac address to start the computer.
    I am wondering if IP address can be used?? you get what I mean? when the machine is powered off, how does it get an ip address assigned???
