  • Shell Moulding
    razajahanian
    razajahanian
    @razajahanian-dvkZXb
    Updated: Oct 23, 2024
    Views: 1.1K
    Shell Moulding
    Shell moulding ;
    It is a process in which the sand is mixed with a thermo setting resin is allowed to come into contact a heated metallic pattern plate ‘so that a them and strong shell of mould is formed around the pattern’ then she is removed the pattern and the cope and drag are remove together and kept in a flask with the necessary back up material and the molten metal is pored into the mould.
    Generally dry and fin sand which is completely free of the clay is used for preparing the shell mould in are the phenol formaldehyde rising combined with sand they hare very high strength and resistance through heat.
    Steps Involve;
    Step 1;
    A metal pattern having the profile of the required casting is heated to 180°-260°c in an own maintained at 300°-400°c pattern after being heated is taken out of the own and sprayed with a solution of a lubricating agent containing silicon. It is necessary to prevent the shell from sticking to the metal pattern.
    Step 2:
    Metal pattern(made up of iron or steel )is then turned faced down and clamped over the open end of the dump box.
    For Complete Details just click Here:
    <If you wish to promote your blog , just make more than 10 posts and you can add a signature _ES>
  • razajahanian
    MemberNov 12, 2010
    Shell Moulding
    Shell moulding ;
    Steps Involve;
    Step 1;
    Step 2:
  • think
    MemberNov 13, 2010
    Hey i'm new to this site so i didn't knew to report it or not but is this stuff allowed here...
    ie someone is directly promoting his/her site ?
  • think
    MemberNov 13, 2010
    Reported 😀
