  • zaveri
    @zaveri-5TD6Sk • May 13, 2013
    If you are talking about punching or blanking operations performed on sheet metal, then the value of the ultimate strength of the material corresponds to the shear strength genaerated, because only if the cutting force is great enough to produce that much of stress, only then will the metal be cut.
  • Ammar Aziz
    @ammar-aziz-7MLZYl • May 13, 2013
    zaveriIf you are talking about punching or blanking operations performed on sheet metal, then the value of the ultimate strength of the material corresponds to the shear strength genaerated, because only if the cutting force is great enough to produce that much of stress, only then will the metal be cut.
    is this also true for orthogonal metal cutting process.......????
  • zaveri
    Ammar Azizis this also true for orthogonal metal cutting process.......????
    orthogonal cutting ? you mean the operations on the lathe ?
    well it has to be , because theoretically the stress induced by the cutting force has to be somehow greater than or equal to the ultimate strength of the material, if some dis-integration of the material (metal) is to take place.
    if the cutting force is lesser then the metal may not cut, but only some stress will be produced in the workpiece.
  • CE Designer
    @ce-designer-BWq0yl • May 14, 2013
    Ammar AzizDear Friends, how we can determine the shear stresses generated within the workpiece due to cutting process applied on it .......... ????
    Are you looking for a formula or an explanation?
  • Ammar Aziz
    @ammar-aziz-7MLZYl • May 14, 2013
    i m looking for stress distribution within the workpice and tool......
  • zaveri
    @zaveri-5TD6Sk • May 15, 2013
    Then in that case you need to apply finite element methods. Try using ansys. But then what exactly is the process which you are dealing with. what is the shape and material of the workpiece and what kind of cutting tool are you using. also what is the material of the tool that you are using.
