serial port communication
zatin_gupta2000
@zatin-gupta2000-PoubI9 โ€ข Oct 22, 2024
hi, this is zatin singhal. actually i want to do communication between two computers using serial port, basically a non IP based communication. It is possible in all languages but I m trying this from 10 dayz but abhi tak i dont get any success. can anybody ther to helpme. i vl b vry thank ful to him/her.
    @harshad-ukH5ww • Sep 23, 2011
    You have connected Serial Cable Between two PCs? If yes then how you connected Serial cable? can you post its Connection?
  • zatin_gupta2000
    @zatin-gupta2000-PoubI9 • Sep 25, 2011
    its simple that u can use the serial cable to connect the ports. simple hardware connection. Now I need the software for data transfer. Can u help me in this.
    @harshad-ukH5ww • Sep 25, 2011
    You can write software in C# or VB . To check whether it's working or not before starting with code you can use any Serial Port Monitoring utility.
  • vishnu tej
    @vishnu-tej-RDU9r1 • May 28, 2015
    This may be useful
  • Loga
    @loga-bSNXfz • Aug 13, 2015
    you can serial port pin No. 2 & 3 to make sure that you get echo while typing in the windows terminal services window.
