Routing and Remote Access in Windows Server 2008 R2
Kishan Gupta
@kishan-gupta-IFXTPJ โ€ข Oct 23, 2024
I recently install windows server 2008 R2 as my home server. It has two NIC card, one connected to internet, and other connected to my private network. Now I enable Routing and Remote Access Role for accessing internet from my private network. It work fine few days, but now it stop working. I can ping my home server; also I am able to use internet on server; but no internet on private network. I use CCProxy, it work fine.
I try disable and re enable service , sometimes it work some times not. I am not very faimilier to these things, so I need your help to solve this problem.
Thank You.
  • durga ch
    @durga-TpX3gO • Mar 3, 2011
    hmm, can you check the Ip address configured for the privte network?
    as far as I can think, you have 2 NICs, say IP address x1 which faces internet and X2 ( on NIC2)which connects to the internal network. Could you check this configuration?
  • PraveenKumar Purushothaman
    @praveenkumar-66Ze92 • Mar 3, 2011
    Can you please send a detailed report of your NIC Configuration and post it here?
  • Kishan Gupta
    @kishan-gupta-IFXTPJ • Mar 3, 2011
    Ya I already check it. CCProxy work fine.
    How I can generate report for it? I have no idea of it.
    Check this out:
  • Kishan Gupta
    This is a primum service.
  • Kishan Gupta
    I have Following error in server manager for this service
    Log Name: System
    Source: RemoteAccess
    Date: 3/3/2011 7:04:36 PM
    Event ID: 20106
    Task Category: None
    Level: Error
    Keywords: Classic
    User: N/A
    Computer: FTP-SERVER-BSACET
    Description:
    Unable to add the interface Internal with the Router Manager for the IPV6 protocol. The following error occurred: The parameter is incorrect.
    jcksnI have Following error in server manager for this service
    Woah! Your OS & ISP?
