How to run single Operating system by using more then one Desktop computer?
Scorpion007
@scorpion007-Mj7x2o May 2, 2026
From my childhood I have an idea to combine more then one old desktop by some method to run single operating system. through this I want get more efficiency speed and memory by combining these desktop. Please tell me is it possible or not?
    @thebigk Dec 25, 2012
    I've a hunch that you're basically talking about cloud computing. You've several computers connected with each other and a 'virtualisation' software that makes it appear as 'one' computer. You can one or more operating systems on the top of it. So, yes it's possible through virtualisation.
  • Scorpion007
    @scorpion007-Mj7x2o Dec 25, 2012
    The_Big_KI've a hunch that you're basically talking about cloud computing. You've several computers connected with each other and a 'virtualisation' software that makes it appear as 'one' computer. You can one or more operating systems on the top of it. So, yes it's possible through virtualisation.
    if i have two desktop of 2.0 Ghz processor speed each.Using your cloud computing idea can I get combined speed 4.0 Ghz
    It won't add up like that, the overall idea is to cover the layer of several physical machines with a virtualisation software and then create individual computers on the top of it. So you might be able to get slightly more than 2 GHz, if you can built an efficient virtualisation software.
    But I'm thinking more in a traditional way. I'm sure the computer experts here will have a lot better ideas.
  • Scorpion007
    @scorpion007-Mj7x2o Dec 26, 2012
    The_Big_KIt won't add up like that, the overall idea is to cover the layer of several physical machines with a virtualisation software and then create individual computers on the top of it. So you might be able to get slightly more than 2 GHz, if you can built an efficient virtualisation software.
    thanks I need more detail
  • Scorpion007
    @scorpion007-Mj7x2o Dec 27, 2012
    Please help if some one have ideas regarding this matter
    @thebigk Dec 27, 2012
    Scorpion007thanks I need more detail
    Have you looked for information on virtualisation and cloud computing? Check it out and tell me if you're proposing the same thing or you've completely different idea in your mind. I'm sure it's going to be an interesting discussion.
  • Scorpion007
    @scorpion007-Mj7x2o Jan 2, 2013
    The_Big_KHave you looked for information on virtualisation and cloud computing? Check it out and tell me if you're proposing the same thing or you've completely different idea in your mind. I'm sure it's going to be an interesting discussion.
    I think it is less concerning with cloud computing. I wana to combine physically computer's hardware of different desktop(May be old) of different configuration to make them one single power full computer it is possible ??
  • Jeffrey Arulraj
    @jeffrey-xA7lUP Jan 2, 2013
    Parallel processing is not so popular cos you need an interface to search for the file This file search is longer as serial searching can be started only at a single point.
    This reduces the processors effective speed. So they introduce interfaces to control and a buffer to store the location of frequently used files. This occupies a large space as a form of Database is used to store the files location
    Electronically Giving a supply of same magnitude and phase to the mother boards is a bit tedious and so this is not advisable But you can give it a go and post its result
    PS: Do note supply to both the CPU's must be from the same outlet otherwise both the boards will be fried
    PSS: Ground terminals of both the CPU's must be shorted Before carrying out trial otherwise trouble is at stake
    PSSS: In short with out knowing hardware throughly don't venture into this
  • Scorpion007
    ConquerorParallel processing is not so popular cos you need an interface to search for the file This file search is longer as serial searching can be started only at a single point.
    Sorry sir I don't really got your point can you explain. first How can I connect physically two Desktop 's motherboard.
  • Jeffrey Arulraj
    @jeffrey-xA7lUP Jan 3, 2013
    <a href="https://www.techspot.com/community/topics/is-it-possible-to-use-two-motherboards.68285/" target="_blank" rel="nofollow noopener noreferrer">Is it Possible to use Two Motherboards? | TechSpot Forums</a>
    Googling is more helpful Cos I ain't got pictures
    Just search and post some things you hit on
    PS: I could not find any reliable sources so I am not 100% into this
    @abhishek-fg9tRh Jan 3, 2013
    There is a reason why single core,dual core,quad core & maybe octet cores are available.
    Many have thought of this,some might've tried & ended up blasting the FETs.
    If you can design a Motherboard with two CPUs,alongwith proper mounting of Northbridge & adequate power consumption then it might be possible.
    There's a way i think,you have to code a kernel & gotta distribute specific tasks to each cpu.BIOS triggers the kernel & assigns all the further hardware control to it.
    Like I said in beginning of this post,why we need more than 1 CPU in single motherboard ?
    But anyhow if you success in this process,it will be an invention & you might see gamers connecting 2 quad core processors in a motherboard with 3x gfx card mounted in SLI,now that computer will run 15x times faster than current high end OCed system.
    But question arises in power consumption,it is possible for MoBo to handle this much of load ?
    This is interesting 😀
  • optimystix
    @optimystix-4yMPKC Jan 4, 2013
    I have done quite a bit of work in cloud computing and though I agree with almost all of what Biggie said earlier, I think adding up of 2+2 ghz of memory may get us closer to almost 4 ghz if done the proper way and using proper technique. Obviously there would be some loss due to the manipulation but the cloud data centres are more or less literally adding memories and speed of computers up by using virtualisation. I may be having the wrong idea, so I would like someone to correct me if I am wrong.
    I always had an idea about combining different internet networks into one superior one ( I had asked it on this forum itself a long time ago) and then it wasn't possible I guess, or maybe we were unaware of it then. But a few days ago I saw an advertisement for some product or software which claimed to add up internet networks of variable speeds and give a superior network of a higher speed. i.e. for eg, combine two different wireless networks of 1mbps each and give out a network of 2mbps. I will post the link if I find that one. I guess I was sleepy when I was looking at it and was careless to leave the topic aside to be read later😔
  • Scorpion007
    @scorpion007-Mj7x2o Jan 6, 2013
    optimystixI have done quite a bit of work in cloud computing and though I agree with almost all of what Biggie said earlier, I think adding up of 2+2 ghz of memory may get us closer to almost 4 ghz if done the proper way and using proper technique. Obviously there would be some loss due to the manipulation but the cloud data centres are more or less literally adding memories and speed of computers up by using virtualisation. I may be having the wrong idea, so I would like someone to correct me if I am wrong.
    oh it is really😔😔 sad
  • optimystix
    @optimystix-4yMPKC Jan 6, 2013
    Scorpion007oh it is really😔😔 sad
    Here it is, I noticed this while I visited site for downloading Connectify. Ive been using Connectify Hotspot for over a year now but I noticed their Dispatch software which was added recently and does what I mentioned above. #-Link-Snipped-#.
  • KenJackson
    @kenjackson-mBf7HF Jan 7, 2013
    I don't understand why the discussion of two desktops morphed into cloud computing and multiple cores. Most window managers or desktop environments in Linux give you multiple desktops regardless of whether you have multiple cores or clouds or not.
    For example, right now I'm running the <a href="https://openbox.org/" target="_blank" rel="nofollow noopener noreferrer">openbox.org</a> windows manager on <a href="https://archlinux.org/" target="_blank" rel="nofollow noopener noreferrer">Arch Linux</a>. Desktop 1 is pretty full, with 8 open windows. But I can press CTR-ALT-right (right arrow) to go to desktop 2 where I currently don't have any windows open. And I can move the current window over there by pressing SHIFT-ALT-right. The very popular #-Link-Snipped-# desktop environment works the same.
    When I find myself bouncing back and forth between two or more different projects, I keep all the stuff for each project on it's own desktop. Is that what you had in mind?
    @abhishek-fg9tRh Jan 7, 2013
    KenJacksonI don't understand why the discussion of two desktops morphed into cloud computing and multiple cores. Most window managers or desktop environments in Linux give you multiple desktops regardless of whether you have multiple cores or clouds or not.
    I think his target is to achieve more processing power .
    Consider,motherboards are resistors-connecting two resistors together gives total resistance as R1+R2 which is > R1 & R2 alone.
    I think OP wanna do same thing connecting two or more MoBos to run single OS for faster performance.
  • Andrew Carter
    @wry-cupcake Sep 28, 2025
    It’s a very interesting idea you shared. Running a single operating system across multiple desktops directly isn’t possible in the way you imagine, but there are alternative approaches. For example, you can create a small cluster where each computer contributes its processing power using distributed computing software. Another option is virtualization, where you can repurpose older machines as nodes for tasks through tools like Proxmox or VMware. If your goal is just better speed and efficiency, upgrading RAM or SSD in one system often gives more practical results. Still, exploring clustering and distributed systems is a great learning path for enthusiasts.
  • Simon Foster
    @crafty-stapler Apr 22, 2026
    Interesting idea, what you’re describing is actually possible, but not in a simple “combine PCs into one OS” way. In practice, this is done using clustering or distributed computing systems, where multiple machines work together while appearing as a single system. Technologies like Beowulf clusters or even modern container orchestration can achieve similar results, though they require proper network setup and software configuration. If your goal is better performance and efficiency, it’s worth exploring these concepts step by step. Also, when experimenting with such setups, keeping track of time vs output (like with tools such as Stundenlohnrechnerr) can help evaluate real efficiency gains
