router configuration problem
Hi,
I came across an article that it is in the data link layer of OSI model that the "router configuration problem" resides. Is this statement true in the first place?
Additionally, what exactly is this "router configuration problem"?
  • durga ch
    @durga-TpX3gO Apr 13, 2016
    link to article
  • pratap singh, upendra
    @pratap-singh-6xlmve Apr 13, 2016
    durgalink to article
    I was solving GATE CSE problems from a book and this question was one of the objective questions in this book
  • Ashraf HZ
    @Ash Jun 12, 2016
    Not sure of the circumstance of that question you saw, but in the networking world, "router configuration problem" is very ambiguous. Router configurations nowadays are advanced enough to extend through the whole OSI layers.
    In most cases of troubleshooting, I suppose issues would fall under Layers 2 & 3.
  • hemantbothra
    @hemantbothra-B4YfuC Jun 12, 2016
    Ash is right it depends on context the statement is mentioned.
    As OSI model is composed of 7 Layer.
    Layer 1 - Physical - cables, connectors and media { electrons(wired) , radio frequency(wireless), light (fibre) }
    PDU - bits
    Layer 2 - Data Link Layer - consist of two sub-layer
    a) LLC (logical link control) which is closer to Network Layer
    b) MAC (media access control) which is closer to Physical Layer and consist of MAC address.
    Devices - network interface card (NIC) which is present in PC, Switches & Routers.
    PDU - Frames
    Layer 3 - Network Layer - logical address i.e. hierarchical addressing.
    Device used is Router, PC or multi-layer switches where you can assign ip address.
    PDU - Packet
    Hence, data link layer is 1st possibility troubleshooting after receiving the signal from the wire (bits).
    One example of Router configuration problem:
    not assigning IP address to an router interface connected to LAN. If somebody on the LAN is trying to ping the router's ip address. Router is not reachable.
