Question Paper -Data Structures through "C" and "PASCAL"
Radhika Deshpande
@radhika-o4Adk0 โ€ข Oct 3, 2024
1. (a) Write an algorithm to multiply two polynomials using linked list.
(b) Let T be a binary tree with height h and n nodes. Show that log(n + 1)- 1 < = h < = (n - 1)/2. For which values of n and h can the above lowest upper bounds of h be attained equality.
(c) Write an algorithm to implement the bubble sort and sort the following list in ascending order using bubble sort :
13, 24, 5, 19, 2, 17, 4
(d) List any three disadvantages of sequential file organization.
(e) Write an algorithm to insert a node before a given node in a linked list.
2. (a) Write an algorithm to convert the following infix expression to the postfix expression and illustrate the position of stack after each step :
z + (y*x-(w/v ? u)*t)*s
(b) Write a recursive algorithm for two way merge sort.
3.Write an algorithm for insertion and deletion of elements in a Queue.
4. (a) Write an algorithm for the breadth first traversal of a graph.
(b) Write an algorithm to insert a node into a Binary Search Tree.
5. (a) What is Direct File organization ? Explain any two advantages of Direct File organization over Sequential File organization.
(b) Write an algorithm for performing Binary Search. What is the condition to perform Binary Search ?
