  • Programming in robots
    Updated: Oct 23, 2024
    I have interested in learning the programming for robots. I want to move the robots by my programming.so, for which what programming language should i learn and what is the way and what is the career in this field?
    C, C++ & C# most useful.
    But Java is also useful in Lego Mindstorm.
    Some applications you need to look upon are :
    Fedora Robotics Spin : spins.fedoraproject.org/en/robotics/#downloads (I suggest you to go for linux fedora 17 distro as it is stable than 18)
    OpenRDK : openrdk.sourceforge.net/
    CARMEN : carmen.sourceforge.net/
    Fawkes : #-Link-Snipped-#
    Player : playerstage.sourceforge.net/
    Robot Operating System : Google it 😀
    Hope this helps 😀
  • [Prototype]
    MemberJan 25, 2013
    It depends. Though most of the processor based systems will directly support ASM & C. If you're loading an OS, then you've a possibility for others like Java. Mostly the high complexity robots will be loaded with Linux or RTOS (like VxWorks).
    In broader terms, C language is the way to go.
