    @ramani-VR4O43 • Sep 12, 2015
    You certainly can. The second Law of Thermodynamics will ensure that you get less energy than the extra energy that the ceiling fan consumes if that is done.
    See here:
  • MINKESHKUMAR RAMOLIYA
    @minkeshkumar-eG8aCB • Sep 12, 2015
    Ohk..thanks...
    @minkeshkumar-eG8aCB • Sep 14, 2015
    sir, i selected my final sem project topic energy produced from ceiling fan...so it's possible that the energy produced from fan will use to charge mobile battery without any more power consumption...
  • lal
    lal
    @lal-R60Xjx • Sep 14, 2015
    Is it a miniature windmill that will be operated by the wind generated by ceiling fan that is in your mind?
    @ramani-VR4O43 • Sep 14, 2015
    #-Link-Snipped-# , maybe something like this?
    Yes something like that...but i am gonna use same concept in fan...
  • lal
    lal
    @lal-R60Xjx • Sep 15, 2015
    I would suggest you do some rough calculations and consider real life scenarios before continuing or planning items for the project.
    A normal PC fan wouldn't rotate by the influence of wind generated by ceiling fan even at its maximum rpm. Which means, a bigger fan will be required. Even if the fan manages to turn, the amount of power generated has to charge the cell at a decent rate.
    Consider the cell phone battery capacity to be 2000mAh. If the charging is to finish in under two hours, 740mA at 5V has to be supplied ideally to the phone. That is around 4W to be generated!
    But, let us say this is free energy shouldn't expect that much. Even 300mA would be a good value. Again, that will depend on the ceiling fan output!
    Choosing the right generator and designing a good turbine and further making it all compact enough to sit on the corner of a table producing enough energy would be a good challenge.
    Keep us posted with the progress.
    @ramani-VR4O43 • Sep 15, 2015
    MinkeshkumarYes something like that...but i am gonna use same concept in fan...
    Please review #-Link-Snipped-#'s post above. The points made deserve attention.
    I have a sneaking suspicion that you are planning to put your generator on the ceiling fan itself. That is a no way street. Willnot work for the reason mentioned above about the second law of thermodynamics. There is no free lunch.
    @minkeshkumar-eG8aCB • Sep 15, 2015
    Sir,we are not using general fan,but using superfan which weight is less and the power consumption also less.we are using rack and pinion mechanism and magnet placed over the pinion hence the rotation of pinion is more hence the magnetic field produced is strong so electricity produed is more...is this possible in general???
    Whatever super duper fan you use, if that fan's drive train is directly running your gadget it is a losing game. Not on.
    You will be better off using direct power to charge your phone. There is no getting around the laws of thermodynamics.
